VF Pallet Pool - Receiver Clamp Plate - Replacement - AD0700
Service Home How To Procedures VF Pallet Pool - Receiver Clamp Plate - Replacement - AD0700
Recently Updated Last updated: 11/07/2024
AD0700
- Jump to Section - 1. Introduction 2. Removal (2 steps) 3. Installation (5 steps) 4. Verification (1 step) Back to Top
This procedure outlines how to replace the clamp plate on a VF-2YT Pallet Pool.
This procedure applies to the following service kits:
  • 93-3823: PP RECEIVER PLATE SERVICE KIT VF-2YT
Removal
Command the Pallet Pool to remove the pallet from the machine.
Remove the rollers and their hardware from the clamp plate that is currently installed in the machine.
Keep these parts as they will be reused on the new clamp plate later in the procedure.
Jog the X-Axis to -28.4 inches (721.36 mm) [1].
WARNING: DO NOT move to the next step without jogging the x-axis to this exact location, if the machine is not in this x-axis location before removing the clamp plate there may be extensive damage done to the receiver assembly and possibly the machine.
Put the machine in E-Stop and pull back the X-Axis waycovers [2].
Remove the 6 bolts [3] from the clamp plate from the machine.
Install the rollers [1] and their hardware [2] from the old clamp plate onto the new clamp plate
Install the ball plunger set screws [1].
Use a dial indicator to measure the height difference between the ball plunger set screws and the rollers [2].
The tip of the set screws should sit 0.030" +/- 0.005" [3] higher than the rollers.
Install the new chip shields to the bottom of the new clamp plate using the provided hardware as shown.
Install the new assembled clamp plate to the receiver with the bolts used from the original clamp plate [1].
The left middle bolt of the clamp plate may require pushing the linear bearing up from underneath the receiver so that the bolt will catch the correct amount of threads.
Once all the bolts have the clamp plate secured in place, torque them to 60 ft-lbs.
Re-install the X-Axis waycovers [2].
Install the nine plugs [1] into the clamp plate. Line up the plug with the hole and use a dead blow hammer to tap in the plug until it is flush with the top of the clamp plate.
Verification
Go to the Pallet Recovery Page and press F2 [1] to clamp/unclamp the receiver and verify the clamp plate is secure.
Run the pallets in and out of the machine to verify the receiver is operating as intended.
