      • Surface Roughness Gauges
      • Hardness Tester
      • Rotary Workholding Kits
H-5AX - VR Double Yoke - HDC - B/C-Axis Compensation
Service Home How To Procedures H-5AX - VR Double Yoke - HDC - B/C-Axis Compensation
- Jump to Section - 1. Introduction 2. B-Axis Compensation (4 steps) 3. C-Axis Compensation (6 steps) Back to Top
Recently Updated Last updated: 07/30/2025
H-5AX - VR DOUBLE YOKE - HDC - B/C-AXIS COMPENSATION
Revision A - 07/2025
This procedure show how to set the B and C-Axis compensations to the VR Double Yoke and HDC-3-5AX machines.
The B and C-Axis Tool Change Offsets should be set before populating the B and C-Axis compensations. See the H-5AX Double Yoke Spindle Head - Geometry Guide procedure for instructions on how to set the Tool Change Offsets.
 Note: The VR Double Yoke machine is shown for illustrative purposes. The same steps will apply to the HDC-3-5AX.
B-Axis Compensation
 Note: B/C Axis compensation tables should only be populated after tool change offsets have been set for B and C.
 Note: B/C Axis compensation tables should be populated before MRZP is run.
Home the B and C-Axis.
In MDI command the B-Axis to +90° and the C-Axis to 0°
Zero the indicator on the bottom of the test bar at Position [1]
Handle jog the X-Axis to Position [2] and adjust the B-Axis position until the error between [1] and [2] is less than .0002”. Note the B-Axis position.
 Note: After adjusting B, make sure to switch back to handle jog [X] in order to engage the brake. The brake will move the test bar. Wait 10 seconds for indicator to settle once the brake is engaged.
[Current Position] - [+90] = [Comp Table Value]
Enter [Comp Table Value] in the 90° cell for the B-Axis [1].
Handle Jog away from the indicator.
Zero Return B-Axis by [B] [ZERO RETURN] [SINGLE] and Verify.
Example: [90.002] - [+90] = +.002
 Note: If the compensation value calculated does not improve the position, delete the value for that position from the table and repeat the steps to calculate the compensation.
In MDI command the B-Axis to -90° and the C-Axis to 0°
[Current Position] - [-90] = [Comp Table Value]
Enter [Comp Table Value] in the 270° cell for the B-Axis.
Zero Return B-Axis and verify.
Example: [-90.002] - [-90] = -.002
C-Axis Compensation
In MDI command the B-Axis to +90° and the C-Axis to +90°
Place an indicator on the left side of the test bar at the end of the bar [1] on the high spot. Zero the indicator at this location.
Jog the Z-Axis up so the test bar clears the table and command B = -90 degrees. Jog the table in the Z and X direction to move the indicator to position [2] on the left side of the test bar at the end of the bar on the high spot. Adjust the C-Axis so that the error on the indicator is the same between positions [1] and [2]. This should not exceed 0.0005".
Once the end of the test bar reads the same error at both B = -90 and B = +90 degrees note the position of the C-Axis.
 Note: After adjusting C, make sure to switch back to handle jog [X] in order to engage the brake. The brake will move the test bar. Wait 10 seconds for indicator to settle once the brake is engaged.
Enter [Comp Table Value] in the 90° cell for the C-Axis.
Zero Return C-Axis and verify.
In MDI command the B-Axis to +90° and the C-Axis to +180°
[Current Position] - [+180] = [Comp Table Value]
Enter [Comp Table Value] in the 180° cell for the C-Axis.
Example: [180.002] - [+180] = +.002
In MDI command the B-Axis to +90° and the C-Axis to -90°
Enter [Comp Table Value] in the 270° cell for the C-Axis.
