Haas Axis Lubrication Oil - Reservoir Refill - AD0630
Service Home How To Procedures Haas Axis Lubrication Oil - Reservoir Refill - AD0630
Recently Updated Last updated: 09/09/2022
AD0630
This procedure outlines how to refill the Haas Axis Lubrication Oil reservoir.
Axis Lubrication Has Changed From Grease to Oil - Service Update
This procedure applies to the following service kits:
  • 93-3584: AXIS LUBE OIL REFILL 1 GALLON
Haas Axis Lubrication Oil - Refill
Power off the machine. Close the primary air valve. This stops the air supply to the machine.
Pull the ring on the pressure relief valve on the air and lubrication manifold. This releases the air pressure from the system.
Place shop towels under the reservoir to catch any grease that may fall.
Remove the empty reservoir. Use an automotive oil filter wrench to loosen it if the reservoir is too tight to loosen by hand.
Pour the Haas Axis Lubrication Oil [A] into the reservoir to 1/2" (13 mm) below the threads on the reservoir.
Install the reservoir [B]. Use your hand to tighten it until the gasket makes contact with the reservoir head. Tighten another 3/4 turn.
Axis Lubrication System - Prime and Test
Press [DIAGNOSTICS].
Go to the Maintenance tab and navigate to the Lube tab.
Press [F2] to start the Axis Lubrication Test.
Perform the Axis Lubrication Test again until you no longer get axis lubrication alarms. Wait a minimum of (1) minute between Axis Lubrication Test cycles.
Check the level of the oil in the reservoir.
If the oil lines were nearly empty, it may be necessary to refill the axis lubrication reservoir after you purge the lines of air. Pour the oil into the reservoir to about 1/2" (13 mm) below the threads on the reservoir.
 NOTE: If the machine has a C-axis, the C-axis gear lube hose must be disconnected from the lube panel manifold during the lubrication air purge process.
