Machine Data Backup (Mill16.xx and higher and Lathe 9.xx and higher) - CHC
Service Home How To Procedures Machine Data Backup (Mill16.xx and higher and Lathe 9.xx and higher) - CHC
- Jump to Section - 1. Introduction 2. Classic Haas Control - Machine Data Backup (Mill16.xx and higher, and Lathe 9.xx and higher) (4 steps) Back to Top
Recently Updated Last updated: 04/29/2025
Data Backup (Mill16.xx and higher, and Lathe 9.xx and higher) - CHC
This procedure will backup all of the machine data files on your machine.
For machines with Mill 15.xx and lower, and Lathe 8.xx and lower, use  Machine Data Backup (Mill 15.xx and lower, and Lathe 8.xx and lower).
To backup only the program files, use Classic Haas Control - Backup Programs procedure.
For this procedure a USB drive on the side of the control pendant or in the electrical cabinet is required.
To find the software version of your machine, push [PARAMETER] (2) times. Navigate to the [CONFIGURATION] tab. The software version is displayed near the top.
Perform this procedure to backup all of the machine data files on your machine.
For machines with Mill 15.xx and lower, and Lathe 8.xx and lower, refer to the Machine Data Backup (Mill 15.xx and lower, and Lathe 8.xx and lower).
To backup only the program files, refer to the Classic Haas Control - Backup Programs procedure.
You must have a USB drive on the side of the control pendant or in the electrical cabinet to perform this procedure.
Prerequisites:
To find the software version of your machine, push [PARAMETER] (2) times. Navigate to the CONFIGURATION tab. The software version is displayed near the top.
Push [SETNG/GRAPH].
Push [PAGE DOWN] until you get to the NETWORK and NETWORK - TCP/IP CONFIGURATION pages.
Record the network settings.
Note: Make sure the customer has a copy of their password, because you cannot read it. Only the characters ****** show.
Put a USB memory device into the USB port on the pendant.
Change Setting 23, 9xxx Progs Edit Lock, to OFF.
Change Setting 157, OFFSET FORMAT TYPE, to A.
For mills with the side-mount tool changer option, change setting 155, Load Pocket Tables, to ON.
Push [LIST PROG]. Navigate to the USB DEVICE tab. Select the USB memory device.
Push [F4].  Select Save All - Back Up. Type a file name. The file name is not important. For example, you can type the machine serial number. Push [WRITE/ENTER].
Note:
  • Mill 18.01A and higher (for 18.xx-Series)
  • Mill 17.06B and higher (for 17.xx-Series)
  • Lathe 11.01A and higher
If your machine does not have the software listed above, Save All - Back Up does not save the keystroke history file (.KEY). You must also use Save History option to save the file.
Note: Save All - Back Up stops if it tries to save bad data. You must use the other menu items to save each of the unsaved Machine Data Files. For example, use Save Offsets to save the offsets.
To restore lost data to a machine from a backup:
  1. Call your Haas Factory Outlet to enable your machine options.
  2. Push [EMERGENCY STOP].
  3. Push [SETTING]. Change setting 7 to OFF.
  4. Insert your memory device.
  5. Push [LIST PROGRAM]. Push [CANCEL].  Select the USB DEVICE. Push [WRITE/ENTER].
  6. Push [F4].
  7. Select Load All - Restore.
  8. Type the name of the back up files you want to restore before the extensions. For example, for file names such as 12345.VAR, 12345.SET..., type 12345.
  9. Push [ENTER]. Push A to restore all backup files.
  10. Power cycle the machine.
