UMC-750 - B-Axis and C-Axis Intersection - Alignment - AD0308
Service Home How To Procedures UMC-750 - B-Axis and C-Axis Intersection - Alignment - AD0308
Recently Updated Last updated: 11/04/2024
AD0308
Applies to machines built from June 2012
- Jump to Section - 1. Introduction 2. B Axis to XYZ Axes Alignment 3. B Axis to C Axis Intersection Tool Setup 4. B Axis to C Axis Intersection Adjustment Back to Top
This procedure shows you how to measure and align the intersection of the B and C axes.  Before attempting this procedure verify that the machine is level per UMC-750 leveling.
You will need to align the B and C axes after you either:
  • Replace the B and C axes
  • or complete a UMC inspection report and find an issue
The 5‑Axis Rotary Center Distance defines the difference between the rotary centers of rotation: C-Axis Machine Rotory Zero Point (MRZP) and the B-Axis MRZP in the X Axis.
It is possible there is no difference between the C-Axis and the B-Axis MRZP.
  • Classic Haas Control (CHC): Parameter 1314 - Rotary Axes Center Deviation in X
  • Next Generation Control (NGC): Setting 254 - 5 Axis Rotary Center Distance
You will need the following tools:
  • T-2195A UMC Aligment Bar Adapter
  • T-2113 Alignment bar
  • Heat gun and heat resistant gloves
How to identify the Multi-Piece and the Unibody trunnion
1) Multi-Piece trunnion:    UMC machines built approximetely before 11/2022 will have this configuration.
2) Unibody trunnion:    UMC machines built approximetely after 11/2022 will have this configuration.
Remove the A-frame trunnion support:
Remove the bolts [1] that secure the A-frame trunnion support [2] to the base and take out the shims between A-frame support and the base.
Rotate the A-frame support [2] counter-clockwise to clear the edge of the base [3].
Pull the A-frame support off the bearings.
 Note: The A-frame support might vacuum lock on the bearings. Use the zip-tie to pry the seal [4] open.
 Caution: To lift the trunnion support, get the aid of another person. The support weighs 85 lbs (39 kg).
Measure the B- axis of rotation parallelism to the Y-Z plane:
For a machine with a Classic Haas Control, change Parameter 151:20 (B axis CHK TRAVL LIM) to 0.
For a machine with a Next Generation Control, change Parameter 6.021 (B axis CHK TRAVL LIM) to FALSE.
Measure the parallelism of the platter to the Y-Z plane with the B axis at 90° and then the B axis at -90° as shown in the picture.
Position the Y-Axis in the following starting position:
UMC-500: Y=0, Sweep 15”, 3rd T-Slot Land from the top.
UMC-750/1500-Duo: Y=-1.0, Sweep 18", 3rd T-Slot Land from the Top .
UMC-1250: Y=-1.0, Sweep 28", 3rd T-Slot Land from the Top.
UMC-500PP: Y=-4.0, Sweep 7".
UMC-750PP: Y=-2”, Sweep 15".
UMC-1000PP: Y=-4”, Sweep 15".
Compare the results at B 90° and B-90°. The results should be...
  • Symmetric against the Y-Z plane, positive or negative direction
  • Less than 0.0010"/20"
If the results are symmetric against Y-Z plane, and are less than 0.0010"/20 inches: Go to Step 5.
If the results are symmetric against Y-Z plane, but are more than 0.0010"/20 inches: Go to Step 4.
 Warning: If the results [3] are not symmetric against the Y-Z plane, the B axis rotary needs to be aligned: Go to Step 3.
Align the B axis of rotation parallel to the Y-Z plane:
Loosen the (6) bolts [1] that secure the B axis rotary to the base casting.
 Note: Keep the bolts sufficiently snug to control the adjustments.
Adjust the front and rear setscrews [2] until the measurements taken in Step 2 are symmetric against the Y-Z plane.
Torque the (6) bolts [1]. Refer to Haas Fastener Torque Specification.
Verify the measurements in Step 2 after the bolts have been torqued.
Align the C Axis of rotation perpendicular to the B Axis of rotation:
Remove the bottom C-Axis access cover.
Loosen the (12) bolts [1] that hold the C Axis body to the B Axis platter face.
Reach the bottom (4) bolts through the C Axis access port.
If the B Axis is symmetric in the positive direction [4], install horseshoe shims [2] of appropriate size behind the top (2) bolts.
If the B Axis is symmetric in the negative direction [5], install horseshoe shims [2] of appropriate size behind the bottom (2) bolts.
Torque the (12) bolts to 80 Ft-lbs (108 Nm).
Cut the excessive shim material off.
Verify the measurements in Step 2 after bolts are torqued.
Align the trunnion support shaft co-axial with the B Axis of rotation:
Setup (2) indicators on the outer race of the trunnion support bearing [2] as shown in the picture.
Mark the spot on the outer race where one of the indicator needles is contacting the surface.
After moving the B Axis to 90° or -90° you will align the marked spot with the needle again to exclude the bearing runout error from the measurements.
Take the readings when B is at 90° and B at -90°. Compare the readings.
 Caution: The B axis brake needs to be clamped when taking the readings.
The deviation between the results when B is at 90° and at -90° needs to be less than 0.001" on each indicator.
 Note: The indicator on the side of the bearing will measure top to bottom alignment and the indicator on the top of the bearing will measure side to side alignment.
____
For models with a multi-piece trunnion
Loosen the (6) bolts [3] on the C Axis body support. Keep the bolts sufficiently snug to control adjustment.
Adjust the (8) set screws [4] until deviation between B at 90° and B at -90° is within 0.001".
Torque the (6) bolts [2] on the C Axis body support to 80 Ft-lbs (108 Nm).
Verify the alignment after the bolts have been torqued.
____
For models with a unibody trunnion
Jog rotary to B90. Set up an indicator on the highlighted surface as shown in the lower diagram .
Rotate B-axis 180 degrees (90 to -90).
Run out (NTE 0.010” TIR).
 Caution: If the measurement exceeds the tolerance then contact support.
Install and shim the A-frame trunnion support:
Move the B Axis to 90°.
Setup an indicator [1] against a machined surface of the C Axis body. Set the indicator to 0.
Use plastic zip ties [2] to pry the seal open while installing the A-frame support. This lets unwanted air and grease out of the assembly.
Install the A-frame trunnion support [3] over the bearings.
Remove the cable ties.
Turn the trunnion support clockwise until it is vertical.
 Note: The weight of the A-frame support will cause the trunnion to sag. The amount of sag is measured with the indicator that was previously setup on the side of the C Axis body.
____
For multi-piece trunnions
Adjust the shims [4] between the A-frame support and the base casting to remove the sag until indicator reads 0 again.
When the indicator reading is 0, torque the (4) bolts. Refer to Haas Fastener Torque Specification.
Verify the reading after bolts are torqued. Adjust the shims again if necessary until the indicator reads 0.
____
For models with unibody trunnion
Determine the amount of shim stock [4] needed to raise the Trunnion arm so the indicator reads 0.005".
The indicator [1] value will change once the support is torqued.
With indicator still in place:
  • Torque trunnion support bolts to appropriate values.
  • Check indicator to make sure it reads between the range of
Trunnion arm raised (0.005” to  0.010”).
 Note: For unibody trunnions, the shim location may also be used to correct the C-axis to X-Y plane perpendicularity instead of shimming the saddle trucks.
 Caution: Use equal amount of shims on each side of the A-frame support. Unequal shims will cause the A-frame support to pull the trunnion to the side.
Verify the B Axis of rotation alignment to the Y-Z plane (Step 2). Loosen the bolts and tap the A-frame support side to side if necessary to correct the B axis to Y-Z plane alignment.
Set C-axis perpendicular to X/Y plane:
Move the axes to
UMC-750's........X= -10.5" & Y=0."
UMC-1000's......X=-17.0" & Y=-0."
Zero an indicator [1], on a Ground Block [2], 1/2" off the edge at the rear of the platter (Mag-Base on Spindle), with C at 0 Degrees
Rotate C-Axis to 180°.
Move Y axis, and ground block, in Y Axis negative direction until you are 1/2" away from platter edge, and take the perpendicularity measurement
Adjust the shims until the average error is within 0.0005" end to end.
 Note: For unibody trunnions, the shim location under the bearing support may also be used to correct the C-axis to X-Y plane perpendicularity instead of shimming the saddle truck.
Caution: Shim either two front trucks or two rear trucks with the equal shim.
Note: Shim one truck at the time to maintain the X to Y squareness.
Verify the measurements after all bolts are torqued.
Verify the X to Y alignment in Step 2.
Set the tool change offsets:
B-axis tool change offset [1]
For Classic Haas Controls, change Parameter 213.
For Next Generation Controls, go to: Settings>Rotary Tab>Highlight the rotary and press [INSERT], or change Parameter 6.078 (B TOOL CHANGE OFFSET) to set the trunnion (B Axis) parallel to the X Axis.
For models with multipiece trunnion
(NTE 0.001/10"; NTE 0.0020" overall)
(NTE 0.0005/10"; NTE 0.0010" overall)
___
C-axis tool change offset [2]
For Classic Haas Controls change Parameter 523.
For Next Generation Control go to: Settings>Rotary Tab> Highlight the rotary and press [INSERT], or change Parameter 7.078 (C TOOL CHANGE OFFSET) to set the table T-slot (C Axis) parallel to the X Axis
Check C-axis perpendicularity to X/Y plane:
Align the indicator centered over the C-axis bore with the Y-axis at -10.
Jog positive in the Y-axis and align the indicator over the center of the last section of the platter and make a mark at this spot with a washable marker.
Insert 1-2-3 block as shown and set the indicator to zero.
Remove the block and rotate the platter 90 degrees, following the marked spot with the indicator.
Insert block back between the indicator and platter. Note reading.
Repeat the previous two steps, taking readings with the platter at 180, 270 and 360 degrees.
Multi-piece trunnion:  (NTE 0.0005")
Unibody trunnion: (NTE 0.001")
Measure the intersection of the B and C axis:
Follow the linked instruction manual to complete this step.
B-Axis and C-Axis intersection Adjustment
Align the B-Axis brake disk:
 Note: Do not do this step if you are working on a SS machine.
Operate this code in MDI mode to unclamp the brake:
M11;
Loosen all of the brake disc bolts [1] and torque them to 5 Ft-lbs (7 Nm).
Operate this code in MDI mode to clamp the brake:
M10;
Wait 10 seconds.
Torque the bolts. Refer to Haas Fastener Torque Specifications.
Install the B Axis and C Axis intersection tool:
Jog the C Axis to 0°.
Push [EMERGENCY STOP].
Clean the table.
Guide the shaft of the adapter [1] while you slowly lower it into the center bore.
Attach the adapter to the table with (2) screws [4] and (2) T-nuts.
Attach the alignment bar [2] to the adapter with (3) screws [3].
Snug the (3) screws to allow for adjustments in the next step.
Align the B/C intersection tool with the C Axis:
Put an indicator on the front side of the alignment bar near the base.
Release the [EMERGENCY STOP]. Push [RESET] to clear any alarms.
Jog across the tool in the X Axis to find the high spot.
Jog the C Axis 360°.
Lightly tap the base with a rubber mallet to adjust the radial error on the alignment bar.
Note: Adjust the alignment bar to half of the measured error, because you are measuring the diameter error.
When correctly adjusted the radial error is less than 0.0002" (0.005 mm).
Check the B/C intersection:
Center the indicator [1] on the front side of the alignment bar near the top of the cylinder.
Zero the indicator.
Turn the (3) screws [2] on the alignment bar to adjust the runout.
Repeat Step 2 and verify the alignment did not change.
Set Parameter 151:20 (B-Axis CK Travel Limit) to 0.
Change CHC Parameter 1314 (ROTARY AXIS CENTER DEVIATION IN X) or  NGC Setting 254 (5-Axis Rotary Center Distance) to 0.
Push [ZERO RETURN]. Then push [ALL].
Jog the B Axis to -90°.
Note: The rotary positions are for reference only.
Put an indicator [1] on top of the alignment bar.
Jog in the Y Axis to find the high point.
Jog across the alignment bar in the X Axis [2].
Jog the B Axis to adjust the alignment bar parallel to the X plane.
Jog the Y Axis to 0.
Caution: Make sure the indicator assembly is clear of the B Axis movement.
 Caution: Do not move the Z Axis.
Jog the B Axis to +90°.
Jog the Y Axis [1] to find the high point on the alignment bar.
Note: Do not set the indicator to 0.
Jog across the alignment bar in the X Axis.
Jog the B Axis to adjust the alignment bar parallel [2] to the X plane.
When the alignment bar is parallel to the X plane, the indicator reading is the change needed in the Z Axis (∆Z=indicator reading).
Record the value shown on the indicator. In this example the indicator now shows 0.0015". ∆Z is 0.0015".
Do these calculations to get the value for CHC Parameter 1314 or NGC Setting 254. (In this example the difference in readings for the B-C intersection (∆Z) is 0.0015".):
  • ∆Z / 2 x 10,000 = CHC Parameter 1314 / NGC Setting 254
  • 0.0015 / 2 = 0.00075
  • Round down to 4 decimal places: 0.00075 = 0.0007 (NGC Setting 254)
  • 0.0007 x 10,000 = 7 (CHC Parameter 1314)
Set Parameter CHC Parameter 1314 (Rotary Axes Center Deviation in X) or NGC Setting 254 (5-Axis Rotary Center Distance), to the calculated value.
In this example, set parameter CHC Parameter 1314 to 7 or NGC Setting 254 to 0.0007.
Cycle the power to save CHC Parameter 1314 or NGC Setting 254.
Repeat Steps 1-3 to verify that the value for ∆Z is less than 0.0002" (0.005 mm).
Jog the B Axis to the home position.
Set parameter 151:20 (B-Axis CK Travel Limit) to 1.
Make sure the MRZP offsets are correct.
Calibrate WIPS per Wireless Intuitive Probe System (WIPS) - Calibration.
Complete an inspection report. Refer to UMC-750 Inspection Report.
