    3. Español
    13. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    3. Español
    13. Русский
Search
50-Taper - Belt Drive - TSC-Ready - TSC - 300 and 1K PSI - Installation - VMC - NGC - AD0293
Service Home How To Procedures 50-Taper - Belt Drive - TSC-Ready - TSC - 300 and 1K PSI - Installation - VMC - NGC - AD0293
Recently Updated Last updated: 12/05/2022
AD0293
Applies to machines built from: January, 2016
- Jump to Section - 1. Introduction 2. Install Kit 3. Tools Required 4. 50-Taper - Belt Drive - TSC-Ready - TSC - 300 and 1K PSI - Installation (11 steps) 5. TSC 1K PSI - Motor Drive PCB and Electrical Components - Installation (5 steps) 6. TSC - 300 and 1K PSI - Pump - Installation (3 steps) 7. TSC - 300 and 1K PSI - Test (2 steps) Back to Top
  1. TSC Coolant Pump
  2. TSC Check-Valve Assembly
  3. TSC Union Assembly
  4. Vacuum Generator
Machine Requirements:
  • Software Version 100.22.000.1000 or higher
Install Kit
To select the correct TSC install kit for your machine refer to: Through Spindle Coolant - Field Install Kits
Tools Required
  • Spindle Lock Tool (T-2080)
  • 1" (25 mm) deep socket
  • Red-I Grease
  • 2 1/4" (57 mm) spanner wrench
  • Dial Indicator (that can measure 0.0001") with Magnetic Base
Push [POWER OFF].
Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
 Danger: If the vector drive voltage indicator light is on, do not touch the electrical components. The high voltage in the control cabinet can kill you. Wait for the voltage indicator LED on the vector drive to go off completely.
Close the primary air valve. Pull the ring on the bleed valve in the air manifold. Wait until all air pressure is released.
Look at the manifold pressure gauge. Make sure that the air pressure is 0 psi.
Remove the spindle head covers.
Install the spindle lock tool (T-2080) onto the spindle.
Put these parts through the cable channels:
  • 20' (6096 mm) 1/4" gray tube [1]
  • 20' (6096 mm) 1/4" purple tube [2]
  • 3/8" hose [A]
Connect the 19" (483 mm) cable [B] to the TSC PRESSURE connector [3] on the electrical bracket.
Remove these parts from the TRP:
  • black tube [1] (discard this tube)
  • elbow fitting [2]
  • reducer fitting [3]
  • Loosen the screw [5] and remove the lock collar [4].
Install and tighten the 50-taper TSC adapter [6]. Use the 2 1/4" spanner wrench.
Install the wave spring [7].
Apply Red-I grease to the union shaft o-ring [8]. Turn the shaft [9] counterclockwise to attach it to the extension tube.
To install the tube extension assembly [2]:
  • Apply molybdenum grease [1] to the tube extension assembly [2] and o-ring.
  • Put the assembly [2] through the TSC adapter.
  • Turn the assembly [2] counterclockwise to tighten. Use the 1" (25 mm) deep socket [3].
  • Torque the assembly [2] to 35 ft-lb (47.4 Nm).
  • Remove the spindle lock tool.
  • Use the dial indicator to measure the total indicated runout (TIR) of the shaft [2].
 Note: The TIR must be less than 0.001" (0.025 mm). If the TIR is more than 0.001" (0.025mm), contact Haas service.
Install these parts on the TSC union assembly [2]:
  • 90 degree fitting [1]
  • brass fitting [5]
Install the TSC union assembly [2]. Use these parts:
  • (4) washers [3]
  • (4) socket-head cap screws (SHCS) [4]
Unlock the main breaker and push [POWER ON].
Run the spindle at 50 rpm. Check for unusual contact between the tube extension assembly and the piston inside the TSC union assembly [2].
Lock the main breaker and push [POWER OFF].
Torque the SHCS [3]. Refer to the Haas Fastener Torque Specifications document. Use the value for aluminum.
Attach these parts to the TSC check valve [2]:
  • Use the (2) 1/4-20 x 1-1/2" socket-head cap screws (SHCS) [1] to attach the check-valve bracket [3].
  • 90 degree fitting [5]
Use the (2) 1/4-20 x 1-1/2" flanged button-head cap screws (FBHCS) [4] to attach the TSC check-valve assembly to the rear spindle-head cover.
Connect these parts to the TSC check-valve assembly:
  • 3/8" hose [A]
  • pressure-sensor cable [B]
  • 20' (6096 mm) 1/4" purple tube [7]
  • 20' (6096 mm) 1/4" gray tube [8]
Connect the gray tube [8] to the fitting [6] on the TSC union assembly.
Connect the high-pressure braided hose [1] to the check-valve assembly and to the fitting on top of the TSC union assembly.
Connect these parts to the TSC union assembly [3]:
  • Use the clamp [4] to connect the 3/8" black hose [5].
  • Connect the 5' (1524 mm) 1/4" gray tube [6] to the push-lock connector [2].
 Note: The next (2) steps will show you how to install the vacuum generator. Choose the correct configuration.
If you have the dome plugs [1] near the front of the spindle:
Remove the plugs [1].
Connect these parts to the vacuum generator [5]:
  • 5' (1524 mm) 1/4" gray tube [2]
  • Use the clamp [3] to connect the 3/8" black hose [4].
Find the space near the front of the spindle. Move the vacuum generator [5] down into the space.
Use a 1/4-20 x 1/2" FBHCS [6] to install the vacuum generator [5].
If the dome plugs [1] are near the rear of the spindle:
Remove the plugs [1] and the bottom spindle-head cover [2].
Put the 3/8" black hose [6] and the 5' (1524 mm) 1/4" gray tube [3] through the opening behind the spindle.
Install the vacuum generator [4] on the cover [2]. Use a 1/4-20 x 1/2" FBHCS.
Connect these parts to the vacuum generator:
  • 5' (1524 mm) 1/4" gray tube [3]
  • Use the clamp [5] to connect the hose [6].
Install the cover [2].
Open the door to the lubrication cabinet.
From the bottom of the manifold, remove and discard the third and fourth manifold plugs [1].
 Note: Clean the manifold port threads.
Install a compression fitting [4] on the TSC-purge solenoid [2]. This solenoid [2] has (2) purple cable ties. Install the solenoid [2] in the third manifold port from the bottom.
Install a compression fitting [4] on the TSC-vacuum solenoid [3]. This solenoid [3] has a gray-cable tie on the push-lock fitting. Install the solenoid [3] in the fourth manifold port from the bottom.
 Note: For TSC-300 Psi, Install The Solenoid [3] With The 35 Psi Regulator. For TSC-1K Psi, Install The Solenoid [3] With The 85-Psi Air Regulator.
Connect the 20' (6096 mm) 1/4" gray tube [6] to the solenoid [3].
Cut the 20' (6096 mm) 1/4" purple tube [8] to the correct length. Connect the tube [8] to the check-valve fitting [9] of the solenoid [2].
Connect the vacuum-solenoid cable [5] to the TSC VACUUM connector on the connector panel.
Connect the TSC-purge solenoid cable [7] to the TSC UNION connector on the connector panel.
Remove the cover [1] for the power supply (PSUP) PCB.
Remove the push-on covers [2] for the connectors from position CB4.
Remove the electrical jumper at position JP2 [3] on the PSUP PCB.
Install the 15A circuit breaker [4].
 Caution: When you handle a PCB, you must wear an Electrostatic Discharge (ESD) strap.
For TSC 1K machines and machines that do not have a door panel installed in the control cabinet.
Open the control cabinet. Remove the cover for the I/O PCB.
Install these parts:
  • Use (2) screws [2] to install the top hinge plate [1].
  • Use (2) screws [3] to install the bottom hinge plate [4].
  • Use (4) screws [5] to install the (2) door brackets [6].
  • door panel [7]
Install these parts on the door panel:
  • (2) spacers [1]
  • motor-drive PCB [G]
  • (2) socket-head cap screws (SHCS) [2]
Connect the 33-1974 cable [H] to these locations:
  • P2 [3] on the motor-drive PCB (put the cable [H] through the left cable-carrier channel).
  • P10 [4] on the I/O PCB.
Connect the 33-0987B cable [I] to these locations:
  • P4 [1] on the motor-drive PCB (put the cable [I] through the top and right cable channels).
  • Connections 77, 78, and 79 [2] on the transformer (each wire has an identification label).
Connect the 12' TSC extension cable [C] to P1 [3] on the motor-drive PCB.
Put the cable [C] through the top and right cable channels.
For TSC 1K machines:
Put the cable [C] behind the cover of the receptacle bracket.
Remove the AUX COOLANT plug [3] from the receptacle bracket.
Install the clamp [2] around the receptacle end [1] of the cable [C].
Use the (2) screws to attach the clamp [2] to the receptacle bracket.
Install the bracket [2] for the fan assembly. Use the (2) 1 x 1/4" Phillips pan-head screws (PPHS) [1]. Make sure the arrows [3] on the fan assembly point in the correct direction.
Install the fan assembly [4] to HS6 [3] on the I/O PCB. Use the (2) 1/4" PPHS [5].
Connect the fan-assembly cable [7] to P11 [6] on the I/O PCB.
  • Remove and discard the larger cover adjacent to the standard coolant pump.
  • Install the smaller cover adjacent to the standard coolant pump.
  • Install the TSC pump [E]. If necessary, remove the #8 fitting [1] and install the #6 fitting [2]. The #6 fitting [2] is for machines that have a 3/8" hose.
On the TSC-purge solenoid, find the fitting [4] that does not have a check valve. Connect the other 20' (6096 mm) 1/4" purple tube [3] to the fitting [4] and to the air cylinder on the pump.
Connect the 3/8" hose [A] to the pump.
If you did not install the 12' TSC extension cable [C]:
Discard the plug [5] for the receptacle bracket.
Install the 12' TSC extension cable [C].
Connect the 4-pin connector [1] of the cable [C] to P31 [2] on the I/O PCB.
Install the receptacle end [3] of the cable [C] to the receptacle bracket. Use the twist lock mount [4] and the screws.
Connect the power cable for the TSC coolant pump to the receptacle end [3] of the TSC extension cable [C].
Install the 13.5' vacuum-sensor cable [D] between P28 [1] on the I/O PCB and to the vacuum sensor [2] for the TSC pump.
Refer ro the Next Generation Control - Option Activation procedure.
Operate this code in MDI:
M59 P26 ;
G04 P5.0 ;
M69 P26 ;
G04 P2.0 ;
M99 ;
P26 is for inline spindles.
For belt-drive spindles, use P35 and not P26.
The bearingless TSC union moves up and down at 7-second intervals. The up and down movement is small.
The illustration shows the up and down movements for 40-taper [1], 40-taper (CALM) [2], and 50-taper [3] machines.
Put a TSC toolholder [1] in the spindle. Push [AUX CLNT] to start the TSC.
Correct operation is as follows:
  1. Coolant flows correctly from the TSC tool holder.
  2. A few drops flow from the vacuum-generator hose [2].
Push [RESET].
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
