      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Mounting QuikChange Cube to Haas Rotary Table - AD0691
Service Home How To Procedures Mounting QuikChange Cube System to Haas Rotary Table - Installation
Recently Updated Last updated: 09/07/2023
AD0691
- Jump to Section - 1. Introduction 2. Installation of the Quikchange system (5 steps) 3. Installation of the Quikchange Cube (2 steps) 4. Installation of the Quikchange Plate (3 steps) Back to Top
This procedure will go over how to install the QuikChange Cube System to an HRT210 or HRTA6.
This procedure applies to the following materials.
  • HQCCS QuikChange System
  • HQCCSA6 QuikChange System, HRTA6
  • HQCCS-PLATE QuikChange System-Plate
  • HQCCSA6-PLATE QuikChange System-Plate
Parts List:
  1. Wrench Housing Subassembly
  2. 4x Socket Head Cap Screws 1/2 x 1"
  3. Compression Spring
  4. Nylon Bushing
  5. 6-point Impact Socket
  6. Draw Bar
  7. Washers
  8. Mounting Block
  9. 6x Socket Head Cap Screws 1/2-13 x 1 1/4"
  10. Quikchange Cube.
For installation on HRT210:
To install the quick change system on an HRT210 [1], screw down the mounting block subassembly [2] using the (6) SHCS and (6) T-nuts [3] supplied and torque to 50 ft/lbs.
For installation on HRTA6:
The HQCCSA6 requires an additional faceplate.
When installing on an HRTA6 [1], an additional faceplate is required [2].
Torque the screws [3] in a star pattern in incremental steps to 15, 35 & 50 ft./lbs.
Then screw down the mounting block subassembly [4] using the (6) SHCS [5] supplied and torque to 50 ft/lbs.
After torquing down the mounting plate, check that the taper [6] run out is less than 0.001" TIR.
Install the drawbar [4] with the nylon bushing [3] and washers [2] into the back of the rotary table. Apply moly grease to the washers [1].
Put the spring [3] inside the socket [2] and install the socket in the wrench housing subassembly [1].  The 3/8"drive of the socket must be engaged in the wrench.
Align the socket with the head of the drawbar and install wrench housing subassembly in the back of the rotary table.
Secure using (4) ½-13 x 1" SHCS and torque to 50 ft./lbs.
Connect the system to the airline. Working air pressure to be 85 – 110 psi.
Note: QuikChange Cubes must be purchased separately.
To install QuikChange Cube, follow these steps:
Align the cube to the drawbar,  making sure groove pins and locating pin are aligned with the grooves on the cube. Hold the lever down for approximately 3 seconds to mount the cube to the rotary table.
After mounting QuikChange Cube System and before fixturing the QuikChange Cube, it will be necessary to mill a skim pass at a minimum depth.  This will provide for a properly squared and flat work surface, as all four sides are in a rough stock condition out of the box.  Tram in the first side to within 0.005” on X and Y over the entire working surface and make the skim cut.  Index the remaining sides 90 degrees and cut to the same Z depth.
Due to variations in pin height on the V-lock plate, the pilot support must be checked for excessive runout.  This is done with the HRT 210 bolted to the mill table and before the A-frame is installed.  Runout should be no greater than 0.004” TIR (total indicated runout) with an indicator at pilot support [1].
If the runout is greater than 0.004”, loosen the (2) 5/16-18 socket head cap screws and tram using a 0.001” test indicator.
Install the A-frame using care to install it on the centerline of the rotary axis.
  1. 5/16-18 SHCS (2) and Washers
  2. A-Frame
  3. Pilot Support
  4. QuikChange Plate
  5. V-Lock Plate
After mounting the QuikChange Plate System, it will be necessary to mill a skim pass at minimum depth for 100% cleanup. This will provide a properly squared and flat work surface, as both sides are shipped in rough stock condition. Tram in the first side to within 0.005” on X and Y over the entire working surface and make the skim cut.  Index the remaining side 180 degrees and cut to the same Z depth.
