Non-Contact Encoder - Rotary - Replacement - AD0573
Service Home How To Procedures Non-Contact Encoder - Rotary - Replacement - AD0573
Recently Updated Last updated: 07/07/2023
AMO Non-Contact Encoder - Rotary - Replacement (2011 - Oct. 2016)
AD0573
- Jump to Section - 1. Introduction 2. Removal (3 steps) 3. Replacement (8 steps) 4. Verification Back to Top
This procedure outlines how to replace the 12V AMO Scale with a 5V AMO Scale on the following rotary trunnions built from 2011 to October 2016:
  • TR160/-2
  • TR160Y
  • TR210
  • TR310
This procedure applies to the following service kits:
  • 93-3419  AMO 5V NCE SVC KIT TR160/-2 2011-2016
  • 93-3420  AMO 5V NCE SVC KIT TR160Y 2011-2016
  • 93-3421  AMO 5V NCE SVC KIT TR210 2011-2016
  • 93-3422  AMO 5V NCE SVC KIT TR310 2011-2016
 You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
 Only authorized personnel with the proper training and certification should do this repair procedure.
 All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
Removal
For NGC:
Go to the enabled Linear Scale Parameter (5.083, 6.083, or 7.083) and set it to FALSE to disable the scale.
Go to Parameter 5.021 and set it to FALSE to disable the travel limits checker.
For CHC:
Go to Setting 7 and set it to OFF.
Go to Parameter 43 Bit 20 and set the CK TRAVEL LIM to 0.
Go to Parameter 269 bit 0 and set it to OFF to disable the scale.
Set Parameters 128 and 212 to 0.
Remove the interpolation assembly bracket [1].
Rotate the trunnion to 180° to remove the counterbalance [2] and mark which hole the counterbalance was mounted to.
Rotate the trunnion back to 0°.
Remove encoder read head [3] and read head mount [4].
Turn off the machine.
Remove the encoder scale using (4x) M6x25 SHCS (40-0083) evenly spaced.
Turn screws 1/2 a turn evenly until the scale ring [5] is removed.
Once the scale is removed, stone burrs smooth on the scale mount left by SHCS when removing the scale.
For TR310
Remove the counterbalance mount and the scale mount entirely and replace with new parts in kit, 20-5599A [1] & 20-5503A [2].
Replacement
Follow this step for TR160/-2 and TR210, otherwise, skip this step.
Install replacement read head mount [2] using the following hardware:
  • TR160/-2 / TR210: 2x 10-32 SHCS (40-1645) & 2x washers (45-1737)
Heat replacement scale with a hot plate to no more than 250°F (120°C) for 4 minutes.
When installing the scale on the scale mount, the dot on the scale mount should be just clockwise (to the left) from the read head [1] when installed.
Install read head [2] on read head mount using the following hardware:
  • 2x 8-32 SHCS (40-1801)
  • 2x washers (45-0042)
Using the provided shim from AMO (.006” ±.004), set the gap between the read head and scale.
Rotate the trunnion back to 180° to reinstall the counterbalance in the previously marked location.
Torque the counterbalance bolts to the following:
  • TR160/-2 / TR210: 50 ft-lbs
Follow this step for TR160Y, otherwise, skip this step.
Print out the stencil at the link below.
TR160Y Template
Line up the stencil [1] to the upper right corner and edges of the driven side of the trunnion.
Mark the hole locations from the stencil onto the trunnion.
Drill and tap 10-32 holes [2] in those locations.
After drilling and tapping, clean the trunnion of any metal chips or fines.
Install replacement read head mount using the following hardware:
  • TR160Y: 2x 10-32 FHCS (40-1702)
When installing the scale on the scale mount, place a dot [3] on the scale mount. The dot should be just clockwise (to the left) from the read head when installed.
Install the read head on the read head mount [4] using the following hardware:
Using the provided shim from AMO (.006” ±.004), set the gap between the read head [5] and scale.
  • TR160Y: 50 ft-lbs
Follow this step for TR310, otherwise, skip this step.
  • TR310: 2x 10-32 SHCS (40-1645) & 2x washers (45-1737)
When installing the scale on the scale mount, the dot on the scale mount should be just clockwise (to the left) from the read head when installed.
Dial in the run-out of the scale to under .0005”.
Once scale run-out is under .0005”. Install read head on read head mount using the following hardware :
Follow this step for all the rotary trunnions
Return the trunnion back to 0° and turn off the machine.
Connect cables 32-10057 [1] and 32-10055B [2] using dielectric grease at the connection.
Replace the existing scale cable with a new scale cable (32-10055B) [2], adapter (32-10057) [1], and J-Box Gasket (57-4133A) [3] using the following hardware:
  • 4x 8-32 BHCS (40-1677) [4]
  • 4x washers (49-4110 [4]
Replace the current sheet metal scale cable cover with a new sheet metal scale cable cover.
Reference this section and image for TR160/-2
Replace necessary gaskets (57-4725A & 57-4726A) to the enclosure.
Install the following hardware and straps in the locations shown:
  • [1] a standoff (20-5629), a SHCS (40-1760), and a cable clamp (59-2040)
  • [2] a velcro cable tie (70-0022)
  • [3] a standoff (20-5629), a SHCS (40-1760), and a cable clamp (59-1334)
  • [4] a velcro cable tie (70-0022) and nylon cable tie (70-0020)
  • [5] a velcro cable tie (70-0022)
  • [6] a cable clamp (59-1334)
Reference this section and image for TR160Y
Replace necessary gaskets (57-0240A & 57-0241B) to the enclosure.
  • [4] a cable clamp (59-1334)
  • [5] a cable clamp (59-2040)
  • [6] a cable clamp (59-2040)
Reference this section and image for TR210
Replace necessary gaskets (57-4133A & 57-4657A) to the enclosure.
  • [4] a cable tie (70-0020) and a velcro cable tie (70-0022)
  • [5] a cable clamp (59-1334)
Reference this section and image for TR310
Replace necessary gaskets (57-4643A & 57-4644A) to the enclosure.
  • [4] a cable clamp (59-2040)
Verification
For NGC:
Turn on the machine.
Set the Linear Scale Parameter (5.083, 6.083, or 7.083) to TRUE to enable the scale.
Set Parameter 5.021 to TRUE to enable the travel limit checker.
Cycle power and zero return the axes.
Follow the Tilting Platter - Offset Adjustment procedure.
Run the trunnion to confirm the scale is working properly.
For CHC:
Set Parameter 43 Bit 20 to 1 to enable the travel limit checker.
Set Parameter 269 Bit 0 to 1 to enable the scale.
Go to Setting 7 and turn it ON.
