      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
VMC - SMTC Cambox - Oil Level Inspection - AD0615
Service Home How To Procedures VMC - SMTC Cambox - Oil Level Inspection - AD0615
Recently Updated Last updated: 04/12/2022
AD0615
- Jump to Section - 1. Introduction 2. Check the oil level (5 steps) 3. Refill the Cambox (2 steps) Back to Top
This procedure covers how to measure the oil level and fill the cambox of a side-mount tool changer (SMTC) on a vertical mill.
Vertical mill SMTC camboxes will have either a sight glass [1] or will have an oil-level plug [2]. The oil-level sight glass and the oil-level plug are in the same location on the SMTC cambox. However, the most effective way to check the oil level is with a dipstick [3].
The recommended oil level has been raised, and 4 inch (101 mm) from the top surface of the cambox is currently recommended for all vertical camboxes no matter when it was manufactured. This is higher than the sight glass and the oil level plug, so these are no longer recommended to use for checking oil level.
Important: If a cambox's oil level is not at the correct height that may not indicate that the cambox is leaking. Over time the cambox will slowly lose oil or the cambox may have been filled to lower oil level previously. Before replacing the cambox do more investigation to see if the cambox has been damaged and is leaking.
    Required parts
  • T-0144 CAMBOX OIL LEVEL DIPSTICK
Check the oil level
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Lock the main circuit breaker. Use an approved lock and an approved safety tag.
Using a Dipstick part 1
Remove any sheet metal necessary to access the top of the SMTC cambox and remove the muffler [1] from the top of the cambox. This can be done with a 9/16-inch wrench.
Using a Dipstick part 2
Make a mark at the point labeled [3] 4 inch (101 mm) from the reference surface [1].
The part labeled [1] will be flush with the top of the cambox. The horizontal labeled [2] should not be used as a reference.
Using a Dipstick part 3
Put the dipstick [1] into the whole at the top of the cambox till it is all the way down as shown in the picture to the left.
Pull the dipstick out and check if the oil is above or below the 4 inch (101 mm) mark made in step 2.
If the oil level is correct, no further action is required.
If the oil level is low, go to the next section.
If the cambox is overfull, do not drain the extra oil.
Using the sight glass or Oil-level plug
Warning: It is no longer recommended to use either the sight glass or oil level plug as they are lower than the recommended fill level.
Remove the carousel cover if it is blocking the sight glass or oil level plug.
Look through the carousel and find the sight glass for the cambox oil level [2], or the oil-level plug [1].
View the oil level through the sight glass [2], remove the oil-level plug [1]. If the oil level is correct, oil comes out of the oil-level hole. Install the oil-level plug.
Refill the Cambox
Use a funnel to add oil to the cambox until it is 4 inch (101 mm) from the top. Check the level again with a dipstick to verify the level is correct.
Note: Refer to Lubricant Table for Haas Machine Components for the correct oil type.
