ACME Screw Tailstock - Troubleshooting Guide - TG0022
Service Home ACME Screw Tailstock - Troubleshooting Guide - TG0022
- Jump to Cause - 1. Overview 2. Symptom Table 3. Quill Specification 4. ACME Screw Alignment (4 steps) 5. ACME Screw Wiper Installation Back to Top
Recently Updated Last updated: 10/08/2025
TG0022
Overview
  1. ACME Screw cover
  2. Tailstock Body
  3. Tailstock Grease Reservoir
  1. ACME SCREW 1.25-5-47"-.625 R-ANC
  2. ACME SCREW NUT 1.25-5 X 2.5
  3. Ballscrew Bumper
  4. Tailstock motor cover
  5. Tailstock Hydraulic Motor
  6. ACME SCREW Bearing Housing Anchor
  1. Coupling Jaw Type
  2. Proximity Sensors
  3. Microswitch Trip Flag
  4. Microswitch (Home Sensor)
  5. Microswitch Mount
  6. Proximity Sensor Trip Flag
  7. Hydraulic Tailstock Motor
NOTE: This system is louder than other tailstock systems, due to the use of a hydraulic motor. This is normal operation and should not be disassembled for troubleshooting unless it is not positioning correctly.
  • Excessive Noise from the tailstock
  • Mispositioning and backlash
  • Binding
  • Low hold force
The ACME Screw and ACME Nut are not lubricated. Clean and lubricate the ACME Screw and ACME Nut. Consider installing service kit P/N 93-4616 to upgrade the lubrication system. Refer to ST-20/30/L - Tailstock Forced Lubrication - AD0804 procedure.
The ACME Screw or ACME Nut are contaminated from chips.
Clean the ACME Screw and ACME Nut and check for damage and wear. Lubricate the screw after cleaning.
Install the B-Axis Protection Service Kit. Refer to the Lathe - B-Axis - Protection Service Kit - Installation procedure. If the Protection Kit was installed before the ACME Screw Wipers were included in the kit. Install 57-0939 to either side of the ACME Nut. Refer to the ACME Screw Wiper Installation section below.
Tailstock is jammed against a part. Remove tailstock ACME Screw front cap and turn the ACME Screw to unjam it. Reduce tailstock hydraulic pressure to 250 psi. There is no need to loosen the hydraulic hoses.
The ACME screw nut may have failed.
Inspect the ACME Screw Nut for damaged threads.  Replace the ACME screw nut if damaged.
Note: Before installing, clean the ACME screw and grease before reassembly.
ACME Screw Misalignment
Check the ACME Screw Alignment. Refer to the ACME Screw Alignment section below.
ACME Screw Nut Housing part geometry
Tapering on Tailstock supported parts Quill pre-load out of specification / Excessive play Check the Quill is within specification. Refer to the Quill Specification section below.
The tailstock zero returns in the wrong direction.  Or the Tailstock mispositions. The tailstock home sensor or trip flag has been damaged from chips.
Clean the ACME Screw and ACME Nut and check for damage and wear. Grease the screw after cleaning.
Inspect the tailstock home sensor and trip flag.  If the trip flag has been failing due to chip build-up install service kit P/N: 93-3393 tailstock home switch retrofit kit. Refer to the Tailstock Home Switch Retrofit - Installation procedure. Only applies to ST-20/25/28 machines built with 20-7462E BASE ST-20 MACH from 07/08/2021 to 09/16/2021 and ST-30/35 machines built with 20-7625D BASE ST-30 MACH from 12/01/2020 to 08/17/2021.
The Tailstock pressure does not adjust. The Programmable Pressure Motor does not turn. Check electrical connections to the pressure switch or motor or for failed hardware such as the pressure valve, hydraulic motor, or coupler. Follow the Programmable Pressure Adjustment Valve - Troubleshooting Guide.
Alarm 9505 or 9505.001 COMMANDED PRESSURE NOT REACHED. The commanded device pressure was not reached within the specified timeout.  Check electrical connections to the pressure switch or motor or for failed hardware such as the pressure valve, hydraulic motor, or coupler. Follow the Programmable Pressure Adjustment Valve - Troubleshooting Guide.
Alarm 437 TAILSTOCK UNDERSHOOT The tailstock did not reach the commanded position. The encoder data isn’t being read during a zero return.
Check the proximity switches and encoder switch trip flag are not obstructed or misaligned from chip build up. Verify the proximity sensors are working correctly. Follow the Proximity Sensor - Troubleshooting Guide. Inspect the tailstock encoder assembly and trip flag. If the encoder is failing due to chip build-up, then clean the encoder area from any debris. For ST-20/30 Series Machines, new encoder brackets will need to be ordered to fix any chip build-up. Refer to: HSG-N 05-29-2024.
  • Check that the values of Setting 341 and 342 (on the user position tab) are correct for the part
  • Check that the part is seated correctly in the chuck.
  • Check that the tailstock was not blocked by the tool turret or another solid object in the machine.
  • For a hydraulic tailstock, check that tailstock hydraulic pressure is not too low.
  • Check the solenoids are operating correctly.
  • Check the ACME Screw Alignment section below.
Alarm 6.9107 B (TAILSTOCK) CHECK YOUR HOME SWITCH The tailstock did not reach the commanded position because encoder data isn’t being read during a zero return.
Note: For software versions 100.23.000.1000 and later, alarm 437 TAILSTOCK UNDERSHOOT will generate in the event encoder data isn’t being read during a zero return.
Check the proximity switches and encoder switch trip flag are not obstructed or misaligned from chip build up. Verify the proximity sensors are working correctly. Follow the Proximity Sensor - Troubleshooting Guide. Inspect the tailstock encoder assembly and trip flag. If the encoder is failing due to chip build-up install the B-Axis Protection Service Kit. Refer to the Lathe - B-Axis - Protection Service Kit - Installation procedure. If the Protection Kit was installed before the ACME Screw Wipers were included in the kit. Install 57-0939 to either side of the ACME Nut. Refer to the ACME Screw Wiper Installation section below.
Home switch not transitioning off/on the home position.
Check the home switch trip flag to make sure it is not obstructed or misaligned. Inspect the tailstock home sensor and trip flag. If the trip flag has been failing due to chip build-up install service kit P/N: 93-3393 tailstock home switch retrofit kit. Refer to the Tailstock Home Switch Retrofit - Installation procedure. Only applies to ST-20/25/28 machines built with 20-7462E BASE ST-20 MACH from 07/08/2021 to 09/16/2021 and ST-30/35 machines built with 20-7625D BASE ST-30 MACH from 12/01/2020 to 08/17/2021.
Install the B-Axis Protection Service Kit. Refer to the Lathe - B-Axis - Protection Service Kit - Installation procedure. If the Protection Kit was installed before the ACME Screw Wipers were included in the kit. Install 57-0939 to either side of the ACME Nut. Refer to the ACME Screw Wiper Installation below.
Motor coupler cracks. When reinstalling the coupler the M6 screws are over torqued. Torque the coupler hardware to the correct torque specification 10 ft-lbs.
Tailstock gets stuck on the part and it will not retract when the tailstock is engaged at full hydraulic pressure. Tailstock settings may not be set correctly. Verify that settings 105 - TailStock Retract Distance, 341 - Tailstock Rapid Position, and 342 - Tailstock Advance Distance are correct.
Quill Specification
Quill Assembly Components :
  1. Quill
  2. O-ring
  3. Quill Liner
  4. Quill Isolator Pads
  5. Quill Retainer
  6. Clamp Collar
Overtime due to the compressive forces exerted on the quill assembly the quill isolator pads deform and become thinner which allows the quill to rotate when it is not compressed.
The quill assembly should not rotate if less than 70 in-lbs (7.91 Nm) of torque is applied to them.
If the quill rotates follow these steps to rebuild it.
  1. Loosen the pinch bolt on the clamp collar
  2. Tighten the clamp collar
  3. Re-torque the pinch bolt
  4. Check the quill again and repeat as needed
Important : Do not overtighten the clamp collar it is only meant to be finger tightened plus an additional 1/8th of a turn.
Note: The clamp collar is pinch bolt is torques to 15 ft-lbs (20.34 Nm).
To test if the quill assembly is damaged / out of spec clamp a work piece [1]  between the chuck and tailstock then use a scale to exert 60 lbs (81.3 Nm) of pull and push force at the tailstock [2] and measure the deflection using an indicator [3].
Note : Ensure that the tailstock pressure is set to 200 PSI (13.7895 Bar).
Deflection NTE 0.0014"(0.03556 mm).
Disconnect the Hydraulic Motor Hoses. Using a collar nut tool and a drill, drive the riser assembly to the motor side of the screw. Loosen all the bolts below and make them finger tight:
  • ACME Nut to ACME Nut Housing[1]
  • Motor Mount[2]
  • Motor Coupler Pinch Bolts[3]
  • Motor Bolts[4]
Torque the bolts in the following order:
Using a collar nut tool and a drive. Run the ACME screw back and forth +/- 2 inches.
  • Motor Mount[2]
  • Motor Coupler Pinch Bolts[3] (10 ft-lbs)
  • Motor Bolts[4]
Reconnect the Hydraulic Motor Hoses.
Use the hand torque meter to test the breakaway torque of the B-Axis at the start middle and end of travel. NTE 15 in-lbs.
If the torque exceeds 15 in-lbs. Continue the ACME Screw alignment.
Remove the Grease Reservoir if installed. Remove the tailstock quill assembly to install a sling through the bore. Remove the tailstock casting to access the ACME Screw Housing hardware.
  • ACME Nut Housing to Tailstock Riser[1]
  • ACME Nut to ACME Nut Housing[2]
  • Motor Mount[3]
  • Motor Coupler Pinch Bolts[4]
  • Motor Bolts[5]
  • Motor Mount[3]
  • Motor Coupler Pinch Bolts[4] (10 ft-lbs)
  • Motor Bolts[5]
If the torque exceeds 15 in-lbs replace the ACME Screw Nut Housing.
Install the each wiper so that the side with the shoulder[1] faces the ACME Nut.
Install the motor side wiper[2] against the ACME Nut with the ACME Nut grease fitting in the middle of the slot.
Install the support side wiper[3] against the ACME Nut with the slot facing down.
Tailstock Hydraulic Motor - Axis Movement Noise Reference
The following service video shows a tailstock hydrualic motor axis movement noise for reference.
