Light Curtain - Troubleshooting Guide
Service Home Light Curtain - Troubleshooting Guide
Recently Updated Last updated: 12/14/2023
- Jump to Cause - 1. Introduction 2. Light Curtain for APL - Service Video 3. Symptom Table 4. Light Curtain for APL - Reset Parameters 5. Light Curtain - Programming Button Cover 6. Light Curtain for APL - Electrical Diagrams 7. Light Curtain for HRP/Cobot - Electrical Diagram Back to Top
The light curtain is a transmitter/emitter and receiver system. When the light curtain is broken, the APL or machine motion will stop until the curtain is unbroken and cycle start is pressed.
There are two types of light curtains:
  • Light Curtain for APL [1]
  • Light Curtain for HRP/Cobots [2]
NOTE: The main appearance difference between the Light Curtain for APL [1] vs. HRP/Cobots [2] is that the Light Curtain for APL [1] has programmable buttons [3] on the bottom whereas the Light Curtain for HRP/Cobots [2] has no programmable buttons on the bottom.
The following video will help to troubleshoot the light curtain used for APL.
NOTE:  This  service video is for reference only and does not replace the written procedure.
Light Curtain for APL Only: The light curtain logic is reversed. When the light curtain is broken the icon (shown below) is not displayed and the I/O is a 0 and the APL motion is not stopped.
The Light curtain parameters are set incorrectly so the logic is reversed. Reset the light curtain parameters. See the Light Curtain for APL - Reset Parameters section below.
The programming buttons were unintentionally pressed changing the parameters. A cover can be made to cover the programmable buttons. See the Light Curtain for APL - Programming Button Cover section below.
Light Curtain for HRP/Cobot Only: The Light Curtain icon does not clear when the Light Curtain is not tripped.
The electrical connections are not correct.    Check the connections from the Light Curtain to I/O PCB. Refer to the Electrical Schematic section below.
There is something interfering the light curtain.   Remove the object interfering the light curtain protective field.
On Multi-sided light curtain the mirrors are not correctly align. Make sure you correct the position of the mirrors.  Refer to the Light Curtain Installation - AD0704 procedure.
The Light Curtain when broken does not trigger the machine to stop APL motion. There is no input from the light curtain to the machine.
Light Curtain wired correctly and receiving power. Check from the PSUP > 24V Transformer > I/O > Light Curtain. Refer to the Electrical Diagram section below.
Light Curtain transmitter and receiver are not aligned.
The Light Curtain Parameter 2191 is not enabled.
The Setting 376 Light Curtain Enable is not turned ON.
Light Curtain for APL Only: Reset the light curtain parameters.
Follow the following steps to reset the Light Curtain Factory Parameters.
1. Press the Menu button to enter parameterization mode.
2. Press the Menu button repeatedly until the F2 icon starts flashing.
3. Press the OK button. This will take you to the 2nd parmaterization level.
4. Press the Menu button repeatedly until the H3 icon starts flashing.
5. Press the OK button. The Light Curtain Parameters will be reset.
See the Light Curtain User Manual below for more information.
Light Curtain - User Manual
If the buttons are pressed and the programming changed unintentionally. A shield can be added to cover the programming buttons.
Install a 0.75 inch wide double sided tape to a 1" x 1" aluminum angle that is 3.5" long.
Apply this to the side of the light curtain to cover the buttons.
The cover should be 1.5" from the bottom of the light curtain[1]. The top of the cover should not exceed 5.25" from the bottom of the light curtain[2] or it will trip the light curtain.
[1] Connect cable 33-1910A CBL90B 115V TO 24V PS from PSUP P5/6/7 to 32-9122 24VDC Power Supply.
[2] Connect 24VDC Power Supply Cable 32-9122 from 33-1910A CBL90B 115V TO 24V PS to 33-0344B CBL LIGHT CURTAIN HARNESS WITH FILTER OV.
[3] Cable 33-0344B CBL LIGHT CURTAIN HARNESS WITH FILTER
[4] Connect cable 32-1847 CBL LIGHT CURTAIN TRANSMITTER to the Light Curtain Transmitter.
[5] Connect cable 33-1558 CBL LIGHT CURTAIN RECEIVER to the Light Curtain Receiver.
[6] Connect Cable 33-0344B CBL LIGHT CURTAIN HARNESS WITH FILTER to the I/O PCB at P1.
[1] Connect cable 33-1281 CBL 50W 24VDC PS 120VAC PWR IN from PSUP P3 to 32-1277 24V Power Supply.
[2] Connect 24VDC Power Supply Cable 32-1277 from 33-1281 CBL 50W 24VDC PS 120VAC PWR IN to 33-8562C CBL 18' HRP SIG FROM I/O TO INTF BOX.
[3] Connect 33-8562C CBL 18' HRP SIG FROM I/O TO INTF BOX to the I/O PCB at P1.
 NOTE: If the machine has a Regen Vector Drive, unplug cable 33-0634 FILTER OV TO IOPCB P1 from P1 SIO and plug it into the connector FILTER OV FAULT on cable 33-8562C. If the machine does not have a Regen Vector Drive, do not plug anything into the connector FILTER OV FAULT.
[4] Connect cable 09-0638 LIGHT CURTAIN EMITTER CABLE from the Light Curtain Emitter to the interface box.
[5] Connect cable 09-0639 LIGHT CURTAIN RECEIVER CABLE from the Light Curtain Receiver to the interface box.
