      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
4 - Gantry - Installation
Gantry-Series Operator's Manual Supplement
  • 0 - Gantry - Table of Contents
  • 1 - Gantry - Introduction
  • 2 - Gantry - Legal Information
  • 3 - Gantry - Safety
  • 4 - Gantry - Installation
  • 5 - Gantry - Control Icons
  • 6 - Gantry - Operation
  • 7 - Gantry - MRZP and Safe Zone
  • 8 - Gantry - G-Codes
  • 9 - Gantry - M-Codes
  • 10 - Gantry - Settings
  • 11 - Gantry - Maintenance
  • 4.1 GM-2-5AX - Installation
  • 4.2 GM-2 - Installation
  • 4.3 GM-1 - Installation
  • 4.4 GR Mill - Installation
AD0799
This procedure will detail how to install a GM-2-5AX machine. For instructions on how to install the GM-2 please refer to the GM-2 Installation procedure.
Additional Tools:
  • T-2181: CNC DUAL LEVELING TOOL
  • T-2192: LEVELING ADAPTER UMC-750
  This procedure should only be performed by certified Haas Service Technicians.
Moving the Machine
The center of mass is depicted in the image for reference while attempting to move the machine.
Please follow the information found in the technical documents section of the machine information page GM-2-5AX machine information for further information on how to prepare for moving a Haas machine.
Leveling Screws Hardware
Note: The washers [1] and nuts [2] are installed during shipping and should be saved for installation and not be discarded.
Note: The washer orientation [3] is important.  The conical part of the washer should be against the casting,  see illustration.
Remove Rust Inhibitor
To safely and effectively remove rust inhibitor from way covers and other non-painted surfaces:
Initial Scraping
  • Use a plastic scraper to remove the bulk of the rust inhibitor.
  • Avoid using metal tools to prevent scratching or damaging the surface.
 Important: Do not use scotch-brite or metal scrapers, these will scratch the way covers.
Chemical Cleaning
  • Spray the affected areas with a heavy-duty citrus cleaner or Simple Green.
  • Ensure full coverage of all non-painted surfaces coated with rust inhibitor.
Soak Time
  • Allow the cleaner to soak for several minutes to loosen remaining residue.
Wipe Down
  • Use a clean shop towel to thoroughly wipe off the softened rust inhibitor.
Rust Proofing
  • Apply mineral spirits or WD-40 to all exposed metal surfaces to prevent future rust formation.
Important: Always wear gloves and eye protection when handling chemical cleaners. Dispose of used towels and cleaning agents according to local environmental regulations.
 Important: To avoid any contamination of the way cover seals with the sticky residue. Do not move any of the axes until all the rust inhibitor has been removed.
Rust Inhibitor - Safety Data Sheet (SDS)
Control Install
Install the pendant cable arm [1].
Route the pendant harness [2] through the arm and attach the harness retainer [3].
Install the pendant arm cover. [4]
Route the pendant cables [1] into the pendant [2] and install the cable harness retainer.
Connect the cables to the SKBIF PCB. Refer to VMC - Pendant - Installation step 2 for connections.
Install the back cover [3].
Attach the  pendant assembly to the pendant stand [4].
Install the dome plugs [5]
Electrical Installation
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
Initial Control Inspection
Danger: At this point, there should be no electrical connection to the machine. Electrical panel must be closed and secured. When main switch is on, there is HIGH VOLTAGE throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures. Therefore, exercise extreme caution when working in the panel.
  • Set the main breaker switch at the upper right of the electrical panel on the back of the machine to OFF.
  • Using a screwdriver, unlock the two latches on the panel door, unlock the cabinet with the key and open the door.
  • Take sufficient time to check all the components and connectors associated with the circuit boards. Look for any cables that have become disconnected, look for any signs damage and loose parts in the bottom of the panel box. If there are any signs that the machine was mishandled, call the factory before proceeding.
1-Phase Machines: Insert each power lead into the wire cover.  Connect the two power leads to L1 and L3 terminals on top of the main circuit breaker.
3-Phase Machines: Insert each power lead into the wire cover.  Connect the three power leads to L1, L2 and L3 terminals on top of the main circuit breaker.
Connect the separate ground line to the ground bus to the left of the terminals.
Refer to Haas Main Circuit Breaker - Torque Specifications for what value to torque the circuit breaker power leads.
 Note: Make sure that the leads actually go into the terminal-block clamps . (A poor connection will cause the machine to run intermittently or have other problems, such as servo overloads.) To check, simply pull on the wires after the screws are tightened.
After the line voltage is connected to the machine, make sure that main circuit breaker (at top-right of rear cabinet) is OFF . Remove the Lockout / Tagout and Turn ON the power at the source. Using a digital voltmeter and appropriate safety procedures:
1-Phase Machines: Measure the AC voltage across L1 & L3 at the main circuit breaker.  The AC voltage must be between 220 - 250 volts .
Note: Lower or higher than this voltage can generate low/high voltage alarms.
3-Phase Machines : Measure the AC voltage between all three pair phases at the main circuit breaker.
The AC voltage must be between 195 and 260 volts (360 and 480 volts for high voltage option).
SMinimill - Reboot: The AC voltage must be between 198 and 242 volts for machines without a high voltage transformer.  Refer to the Minimill/SMinimill - Identification document.
 Note: Wide voltage fluctuations are common in many industrial areas; minimum and maximum voltage supplied to a machine while it is in operation must be known. U.S. National Electrical Code specifies that machines should operate with a variation of +5% to -5% around an average supply voltage. If problems with line voltage occur, or low line voltage is suspected, an external transformer may be used. If you suspect voltage problems, voltage should be checked every hour or two during a typical day to be sure it does not fluctuate more than +5% or -5% from an average.
Important: With the main circuit breaker turned OFF.
Check the transformer taps at the bottom-right corner of the rear cabinet.
1-Phase Machines: The input voltage cable must be moved to the connector which corresponds to the average voltage measured in the above step.
3-Phase Machines:  The input voltage cables labeled 74, 75, and 76 must be moved to the terminal block triple which corresponds to the average voltage measured in the above step.
Transformer T5 supplies 24VAC used to power the main contactor. There are two versions of this transformer for use on a 240 and 400V machines. The 240V transformer has two input connectors located about two inches from the transformer, which allow it to be connected to either 180-220V or 221-240V.
Users that have 220V-240V RMS input power should use the connector labeled 221-240V, while users with 190-220V input power should use the connector labeled 180-220V. Failure to use the correct input connector will result in either overheating of the main contactor or failure to reliably engage the main contactor.
The 480V (option) T5 transformer has three input connectors, labeled 340-380V, 381-440V and 441-480V.
Users with 340-380V 50/60Hz power should use the 340-380V connector while users with 380V-440V 50/60Hz power should use the 381-440V connector.
Important: Set the main circuit breaker to ON. Check for evidence of problems, such as the smell of overheating components or smoke. If such problems are indicated, immediately set the main circuit breaker to OFF and call the factory before proceeding.
After the power is on, measure the voltage across the bottom terminals on the main circuit breaker. It should be the same as the measurements where the input power connects to the main breaker. If there are any problems, check the wiring.
Apply power to the control by pressing the Power-On switch on the front panel.
Check the DC Voltage and AC Line Voltage gauges in Diagnostics. The DC Voltage gauge must read between 310 - 360V. The AC Line Voltage must be between 90 and 105 percent. If the voltage is outside these limits, turn off the power and recheck steps 2 and 3. If the voltage is still outside these limits, call the factory.
Electrical power must be phased properly to avoid damage to your equipment. The Power Supply Assembly PC board incorporates a "Phase Detect" circuit with neon indicators. When the orange neon is lit (NE5), the phasing is incorrect. If the green neon is lit (NE6), the phasing is correct. If both neon indicators are lit, you have a loose wire; check the connections. Adjust phasing by setting the source power to off and then swapping L1 and L2 of the incoming power lines at the main circuit breaker.
Danger: ALL POWER TO CNC MUST BE TURNED OFF LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO ADJUSTING PHASING. ALWAYS DOUBLE CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR.
Turn off the power and set the main circuit breaker to OFF. Close the door, lock the latches, and turn the power back on.
Remove the key from the control cabinet and give it to the shop manager.
Activation
When the machine is properly placed and connected to both air and electrical power, it is ready for final installation (removing shipping blocks, leveling, spindle sweep, etc.) and software activation. The HFO service technician does this. Contact the local HFO to schedule the work.
Connect Air Supply
Connect the air supply to the air inlet fitting [1].
Verify that the Tool Release Pressure gauge [2] read 140 - 160 psi. Adjust the knob on the back side of the air doubler [3] if needed.
The Spindle Air Purge gauge [4] should read 45 psi whenever the spindle is in operation. Adjust the knob on the air regulator [5] if needed.
Rough Level
Before first power on, rough level the machine.
IMPORTANT : For dual ballscrew machines it is important to rough level before a first power on, as not doing so might cause the machine to alarm out during the X-axis during the zero return process.
  • Adjust the leveling screws to raise the machine 3" (H) from the floor.
  • Place the bubble level on the center of the table parallel to the Y-Axis. Adjust the leveling screws to level the table.
NOTE: The image shows a carpenter level, this is for REFERENCE ONLY.  Please use a machinist level to rough level the machine
  • Place a bubble level on the center of the table parallel to the X-Axis. Adjust the leveling screws to level the table.
Remove Shipping Brackets
Remove three bolts [1] that secure the B axis body [2] to the spindle head shipping bracket [3].
Remove four bolts [4] that secure the spindle head shipping bracket to the table and remove the shipping bracket from the machine.
Install the plugs [5] into the  shipping bracket mounting holes on the B-axis body.
To unblock Y axis:
  • Remove the Y axis shipping bolts [1] that secure the Z axis sub plate [2] to the bridge.
To unblock X axis:
  • Remove two bolts [3] that secure the X axis shipping bracket [5] to the gantry column.
  • Remove two bolts [4] that secure the X axis shipping bracket [5] to the table.
  • Remove the shipping bracket [5].
  • Reinstall the table bolts [4].
  • Perform the same steps to remove the shipping bracket [6] on the other side of the gantry.
Install Column Covers
  • Install the provided column cover ENCL PANL PAN LIFT ACCESS M VF as shown using 4 x FBHCS 1/4-20 X 1/2 LOCTITE screws.
  • Install the two provided column vent covers SP HD TOP BACK COVER VENT UMC as shown using 2 x FBHCS 1/4-20 X 1/2 LOCTITE screws for each.
  • Install the provided column cover ENCL PANL COLUMN COVER as shown using 3 x FBHCS 1/4-20 X 1/2 LOCTITE screws.
Install the Enclosure Panels
Install the enclosure frame over the tool changer and secure it to the bridge using four 1/2-13 bolts and washers.
Refer to the Haas Fastener Torque Specifications for the correct torque value
NOTE: The weight of the frame weldment is approximately 160 lbs. Use the forklift or other lifting device to lift the frame.
Install the front enclosure frame tubes [1] as shown on the picture.
Use the following hardware [2] to secure the frame tubes:
  • 8X SHCS 3/8-16 X 3"
  • 8X NUT 3/8-16 HEX
  • 16X WASHER 3/8 HARD
Install panels 1-8, (front and left side)
1 - ENCL PANL LEFT TOP COLUMN GM 5AX
2 - ENCL PANL FRONT CENTER GM
3 - ENCL PANL FRONT CENTER GM
4 - ENCL PANL FRONT LT GM
5 - ENCL PANL LT GM
6 - ENCL PANL LEFT TOP GM 5AX
7 - ENCL PANL FRONT LT GM 5AX
8 - ENCL PANL REAR GM
Install the stiffener brackets [1] & [2] in the location shown in the image.
Follow the next step for further instructions of the orientation of the stiffner brackets.
Install the left stiffener bracket [1] and the right stiffener bracket [3] to the enclosure.
Mount the left stiffener bracket [1] in the orientation shown with the 90 degree angle on the inside of the enclosure. This bolts to the enclosure highlighted in red as [2].
Mount the right stiffener bracket [3] in the orientation shown with the 90 degree angle on the inside of the enclosure. This bolts to the enclosure highlighted in red as [4].
Install panels 1-4, (left / back)
1 - ENCL PANL LEFT COLUMN COVER GM 5AX
2 - ENCL PANL BACK LEFT TOP GM-2
3 - ENCL PANL BACK LEFT TOP GM 5AX
4 - ENCL PANL BACK LEFT BOTTOM GM-2
Install panels 1-3 (left / bottom)
1 - ENCL PANL LEFT PAN GM
2 - ENCL SPLASH GUARD FRONT LEFT GM
3 - ENCL PANL LEFT BOTTOM COLUMN GM 5AX
 NOTE: A GM-2-3AX is shown in the image, but the steps will be the same for the 5AX
Install the splash guard [1].
Install chip auger chutes [2]. Refer to the  Chip Auger - Installation steps 5 and 6.
Install Safety Sensors
Install the safety sensors on each corner of the moving enclosure.
  • [1] Rear left safety sensor is 33.5" long.
  • [2] Front left sensor is 50" long.
  • [3] Front right sensor is 18" long with 29 ft cable.
  • [4] Rear right sensor is 18" long with the 17 ft cable.
Route the safety sensor cables.
  • The 33-0606 [1] cable is routed through the left side column from the factory. Connect the 33-0606 to the rear left  safety sensor.
  • Route the 33-0626 [2] cable from the rear left to the front left safety sensor.
  • Route the 33-0624 [3] cable from the front left to the front right safety sensors.
  • Route the 33-0623 [4] cable from the front right to the rear right safety sensor.
Check the Spindle Chiller
 Note: VR and GM machines built before 5/9/2025 are equipped with the VR/GM Spindle Heat Exchanger. VR and GM machines built from 5/9/2025 and after are equipped with the VR/GM Spindle Chiller. Use the sections that pertain to your specific chiller unit.
Check the spindle chiller for any air bubbles in the lines by running the spindle.
Then, check the flow sensor [1] and make sure the machine does not receive any alarms.
If any alarms or issues arise with the spindle chiller please visit the VR/GM - Haas Spindle Chiller Troubleshooting tab in the Haas Spindle Chiller - Operator's/Service Manual for more information.
Zero Return
 Danger: The safety edge sensors are not active when the machine is in handle jog mode. If the X-axis gantry is handle jogged into an obstacle the collision will not be detected by the safety edge sensors.
  • After the machine is powered on, cycle the door and the [EMERGENCY STOP] button. Then press [POWER UP].
  • The Zero-Return popup will appear. If the machine is in a safe position press A and the GM-2-5AX will zero return the axes in the following order
    • 1. Z
    • 2. X and Y
    • 3. C (5th), TC Arm, Carousel
    • 4. B (4th)
  • If there is an obstacle above the B/C axis assembly, such as the tool changer double arm, when the machines is commanded to zero return all axes, the B/C axis assembly will collide the double arm because the Z-Axis is always zeroed first.
  • To avoid this collision press [HANDLE JOG] when the Zero Return popup appears. This will temporarily enable Jog Without Zero Return. Jog the machine to a safe position then, zero return all axes.
Fine Tuning Level/Adjusting for Twist
  • Jog the spindle head about half way of the Z-axis travel
  • Place the level tool on the spindle as shown parallel to the Y-Axis.
  • Jog the bridge across the full travel. Verify that the readings are within the limit of 0.0002 in (0.005 mm) over the full travel.
  • Adjust the leveling feet as necessary. Re-check the bubble level.
After leveling, complete a full GM-2-5AX Inspection report (EA0421) by following the link to the Alignment, Inspection Report and Checklist.
GM-2 - Installation
AD0798
This procedure will detail how to install a GM-2 machine. For instructions on how to install the GM-2-5AX please refer to the GM-2-5AX Installation procedure.
Additional Tools:
Moving the Machine
Please follow the information found in the technical documents section of the machine information page GM-2 machine information for further information on how to prepare for moving a Haas machine.
Initial Scraping
Chemical Cleaning
Soak Time
Wipe Down
Rust Proofing
Control Install
  • Do not proceed.
Activation
Connect Air Supply
Connect the air supply at the lube panel.
NOTE: For air requirements refer to the decal that is located on the lube cabinet door.
  • 8X NUT 3/8-16 HEX
NOTE: A GM-2-5AX is shown in the image, but the steps will be the same for the 3AX
Install panels 1-6, (front and left side)
1 - ENCL PANL LEFT TOP COLUMN GM-2
5 - ENCL PANL LT GM
6 - ENCL PANL REAR GM
Install panels 1-2, (left / back)
1 - ENCL PANL BACK LEFT TOP GM-2
2 - ENCL PANL BACK LEFT BOTTOM GM-2
2 - ENCLOSURE SPLASH GUARD FRONT LEFT GM
3 - ENCL PANL LEFT BOTTOM COLUMN GM-2
Rough Level
To unblock Y axis:
To unblock the X axis:
  • Remove two hardware that secure the X axis shipping bracket [1] to the gantry column and the table.
  • Remove the shipping bracket [1].
  • Reinstall the table bolts.
  • Perform the same steps to remove the shipping bracket on the other side of the gantry.
To unblock the spindle head:
  • The machine must be power on.
  • Do not power up reset/zero return the machine
  • After initial start up press [SETTING] and navigate and set setting 53 JOG WITHOUT ZERO RETURN to TRUE.
  • Raise the Z-axis until the spindle is out of the shipping bracket [2] and remove the shipping bracket from the table.
Zero Return
  • Verify that there are no obstacles in the way of each axis and the shipping brackets have been removed, then press [POWER UP] and follows the prompts on the controller.
  • Attach the level tool to the spindle, with the tool facing as shown in the image.
  •  Jog the X axis to either end of the base and read the measurements.
  • Adjust the leveling screws as need be to raise or lower a corner of the base until the bubble closely match end to end.
  • Readings are NTE 0.0002 in (0.005 mm) over the full travel.
After leveling, complete a full GM-2 Inspection report (EA0421) by following the link to the Alignment, Inspection Report and Checklist.
GM-1 - Installation
AD0865
Revision A - 8/2025
This procedure will detail how to install a GM-1 machine.
Required Tools:
Moving the Machine
Please follow the information found in the GM-1 Pre-Installation Guide for further information on how to prepare for moving a Haas machine.
Initial Scraping
Chemical Cleaning
Soak Time
Wipe Down
Rust Proofing
Control Install
Route the pendant harness[1] through the arm and attach the harness retainer[2].
Install the pendant arm cover[3].
Route the pendant cables[1] into the pendant[2] and install the cable harness retainer.
Install the back cover[3].
Attach the pendant assembly to the pendant stand[4].
Install the dome plugs[5].
  • Do not proceed.
Activation
Connect Air Supply
Install Tool Changer
Important: Use the proper lifting equipment as shown to support the tool changer and mount (approx. 450 lbs. / 204 kg).
Install a 1/2"-13 hoist ring with 1.25" thread length to the back of the tool changer casting.
Remove Tool Changer from shipping mount and install to the side of the bridge.
Connect the TT[1] and TA[2] servo motor power cables and encoder cables.
Connect the Pocket Up/Down air lines to the cylinder.
  • Pocket Up - Green hose - Top push-to-connect fitting.
  • Pocket Down - Red hose - Bottom push-to-connect fitting.
Route the Tool Changer axis lube line[3].
Connect the Tool Changer Pocket position proximity switches[1] to the Tool Changer bracket.
Remove the pockets [1] to access the Tool Changer lube line fitting.
Connect the Tool Changer axis lube line[2].
Reinstall the pockets[1].
Install the Tool Changer enclosure panels.
Install Enclosure Panels
Remove the hardware[1][2] securing tool changer enclosure in its shipping position.
Pull out the enclosure[3] and reinstall the hardware in the extended position.
Install TC enclosure panels.
Install chip auger chutes[1]. Refer to the Chip Auger - Installation steps 5 and 6.
Install the coolant splash guards.
Install the safety sensors on the TC enclosure.
[1]  Front left safety sensor is 38" long.
[2]  Rear left safety sensor is 18" long.
Install Operator Window
Install the window[1].
Insert the grommet[2] to the top bracket. Bolt both brackets[3] to the enclosure above the window.
Remove bottom nut[4] on the cylinder to slide it through both brackets. Install the bottom nut[4] to secure to the cylinder to the window.
Insert bottom of cylinder shaft through the window bracket's hole and secure with jam nuts[5].
Assembled Operator Window Assembly.
Loosen the sensor clamp[1] until the opening is wide enough to fit around the cylinder. Place the clamp around the bottom of the cylinder.
Insert the sensor[2] in between clamp and cylinder. Tighten the sensor clamp[1].
Attach two hose fittings[3] to the bottom and top of the cylinder.
Connect the gray airline[4] to the bottom hose fitting on the cylinder and connect the yellow airline[4] to the top hose fitting on the cylinder.
Push [EMERGENCY STOP].
Close the Operator Window.
Do these steps to adjust the sensor indicating when the Auto Window is closed. Monitor the DIAGNOSTICS > I/O tab at the same time:
  1. Loosen the sensor clamp. Move the sensor and clamp until Input 67 LEFT_DOOR_OPEN changes from 1 to 0.
  2. Slowly move the sensor and clamp up. Find the location where the value is as near as possible to 0, but the value is 1. Put a mark on the cylinder above the switch to locate the sensor's height at this position.
  3. Move the sensor and clamp down. Find the location where the value is as near as possible to 0, but the value is 1. Put a mark on the cylinder below the switch to locate the sensor's height at this position.
  4. Move the sensor and clamp to the middle point between the two marks. Input 67 LEFT_DOOR_OPEN should be a 0 at this position.
  5. Tighten the clamp.
 Important: Move any wires and hoses around to prevent any kinks or rubbing before the enclosure cover is put on.
Secure both airlines and sensor cable to the cylinder with zip ties.
Install the cover[1] to the machine's enclosure above the window.
Connect and route both sensor wires and airlines[2] through the cover.
Rough Level
IMPORTANT : For machines with long ballscrews it is important to rough level before a first power on, as not doing so might cause the machine to alarm out during the X-axis during the zero return process.
Use a machinist level to rough level the machine. Place the level on the center of the table parallel to the Y-Axis. Adjust the leveling screws to level the table.
Use a machinist level to rough level the machine. Place the level on the center of the table parallel to the X-Axis. Adjust the leveling screws to level the table.
X-Axis Shipping Brackets:
  • Remove the hardware that secures the X axis shipping bracket to the gantry column and the table.
  • Remove the shipping bracket.
Spindle Head Shipping Bracket:
  • The machine must be powered on.
  • Do not power up reset/zero return the machine.
  • After initial start up press [SETTING] and navigate and set Setting 53 JOG WITHOUT ZERO RETURN to TRUE.
  • Raise the Z-axis until the spindle is out of the shipping bracket and remove the shipping bracket from the table.
Y-Axis Shipping Bracket:
  • Remove the Y axis shipping bolts that secure the Z axis sub plate to the bridge.
TC Shipping Bracket:
  • Remove the TC Shipping Bracket from the bridge.
Zero Return
After leveling, complete a full GM-1 Inspection Report (EA0455) by following the link to HBC.
AD0092
This installation procedure for the GR Mill tells you how to:
  1. Move the GR Mill into position for setup.
  2. Remove the spindle-head shipment screws.
  3. Remove the shipping brackets.
  4. Reposition the pendant arm.
  5. Reposition the 20-pocket tool changer.
  6. Align 20-pocket tool changer.
  7. Install the chip and coolant splash shield.
  8. Install the electric safety sensors.
Use a forklift that can lift a minimum of 18,000 lb (8165 kg). The illustration shows an estimate of the correct forklift [1] position.
Removal of Rust Inhibitor
Electrical Connections
  • Do not proceed.
Activation
Shipping Brackets - Removal
  • Remove the (2) screws [1] that prevent Y-Axis movement.
  • Attach the cover [2] with the (3) screws.
  • Remove the (4) screws [1] that attach the shipping bracket to the bridge.
  • Remove the (4) shorter screws [2] from the side of the shipping bracket. Keep these screws.
  • Remove the (4) longer screws [3] that attach the shipping bracket to the table. Keep the screws.
  • From the rear of the shipping bracket, remove the (2) screws [4] that attach the shipping bracket to the spindle.
Note: Keep the screws with the shipping bracket. If you must move the machine to a different location, you can install the bracket.
Note: If the machine has the optional Extended Z-Axis Clearance 6" (152 mm) or 24" (610 mm) riser option, the bracket separates into (2) pieces.
  • Install the (4) shorter screws [2] that you removed from the side of the shipping bracket into the table.
  • Torque the screws. Refer to Haas Fastener Torque Specifications. Use the value for aluminum.
  • Remove the pendant shipping brackets.
  • Remove the screw [1] and the spacer from the top of the arm joint. Keep the screw and the spacer.
  • Turn the arm [2] to the operation position.
  • Insert the screw [3] and the spacer into front of the joint. Torque the screws. Refer to Haas Fastener Torque Specifications. Use the value for steel.
  • Pull the boot over the joint and tighten the clamps.
20-Pocket Tool Changer - Alignment
Note: This step applies to 20 pocket TC only.
  • Support tool changer with hoist.
  • Remove 4 SHCS attaching the TC arm.
  • Turn tool changer around 180 degrees.
  • Install 4 SHCS to reattach TC arm.
  • Adjust the tool changer assembly where it mates with the machine [1], so that the spindle dog [2] aligns with the tool alignment key [3].].
  • Tighten and then torque the (4) screws that hold the tool changer to the machine. Refer to Haas Fastener Torque Specifications. Use the value for steel.
  • Make sure Parameters 257 and Parameter 64 are correct.
  • Do these procedures:
Umbrella Tool Changer - Spindle Orientation Offset - Parameter 257
Umbrella Tool Changer - Set Parameter 64 - Z Axis Tool Change Offset
Chip and Coolant Splash Shield - Installation
  • Apply Sikaflex construction sealant (or equivalent) where you will attach the drip tray. Apply the Sikaflex along the full distance. This prevents coolant leakage.
  • Attach the front drip tray. Use the (9) 3/8-16x1/2 socket head cap screws (SHCS) and (9) washers. Torque the screws. Refer to Haas Fastener Torque Specifications. Use the value for steel.
  • Apply Sikaflex construction sealant (or equivalent) to the space on each side [1] of the drip tray.
  • This illustration shows where to apply Sikaflex construction sealant (or equivalent) to the spaces from the rear view.
  • Find the (2) hooks [1].
  • Hang the outer frame piece onto hooks on the inner frame piece. Use a lifting device.
  • In the subsequent steps, keep all of the screws loose until you assemble all the frame parts. Then tighten them.
  • Attach the outer frame piece onto the inner frame piece. Use the (7) 3/8-16 x 1" socket head cap screws (SHCS). Use (1) nut and (2) washers for each screw, as shown.
  • Put the (3) plastic covers into the holes that point into the machine.
  • Remove the frame shipping brackets. There is (1) middle piece [1] and (2) end pieces [2].
  • Remove the small cover plate.
  • Keep the cover plate.
  • For the subsequent steps, install the screws loosely. Tighten the screws after you install all the parts.
  • Install the (2) 1/4-20 x 1/2" button head cap screws (BHCS) [1]. Hang the first cover piece [2] over the screws.
  • In some of the subsequent steps, you attach an enclosure piece [1] to the frame [2]. Use the 1/4-20 x 3/4" BHCS for those steps.
  • In other subsequent steps, you attach (2) enclosure pieces together [1]. Use the shorter 1/4-20 x 1/2" BHCS for those steps.
  • In some positions, an enclosure piece attaches to the frame with the long 1/4-20 x 3/4" BHCS [1]. And the same enclosure piece attaches to another enclosure piece with the shorter 1/4-20 x 1/2" BHCS [2].
  • Get the cover plate you removed in step 6. Install the cover plate with the (4) 1/4-20 x 3/4" BHCS.
13
  • Install the next enclosure piece.
14
  • Use the flanges [1] to hang the next enclosure piece over the frame piece [2].
  • Do not install the screws at this time.
  • Note: Machines with the 6.00" (152 mm) or 24" (610 mm) riser option [1] have one more enclosure piece [3]. Apply the foam tape [2] to the top of the enclosure piece [3]. Then attach the enclosure piece [3]. This image shows the 24" (610 mm) riser option.
16
17
  • Attach the (2) enclosure pieces to the frame. Use the 1/4-20 x 3/4" BHCS..
18
  • Apply foam tape [1] to the next enclosure piece. Then install the enclosure piece [2]..
19
  • Apply foam tape to the drip tray as shown [1]. Extend the foam tape onto the small inner flanges [2].
  • Install the drip tray [3] with the (4) 1/4-20 x 3/4" BHCS.
  • Tighten all of the screws for all of the enclosure pieces.
20
  • Apply Sikaflex construction sealant (or equivalent) [1] to the space between the drip tray [2] and the bottom enclosure piece.
Caution: Coolant leakage can occur through all of the spaces between the enclosure pieces. Apply Sikaflex construction sealant (or equivalent) to all of these spaces.
21
  • Put the magnets on the (2) brackets at every other space.
22
  • Put the brackets with the magnets in these positions:
  • on the inner surface of the front of the enclosure [1]
  • onto the back of the bridge [2]
. Caution: The magnets pull the brackets onto the bridge with strong force. Do not put your fingers between brackets and the bridge or you may injure your fingers.
23
  • Attach the vinyl flaps to the brackets. Use the 1/4-20 x 1/2" BHCS.
24
  • Move the brackets up or down to adjust the distance of the flaps from the table.
Safety Sensors - Installation
  • Image shows how the Safety Sensors are oriented on the machine. The safety sensors are labeled 1-4.
Note: The sizes of each sensor and the locations on the machine.
  • Each Sensor has two endcaps/connections, a female endcap and a male endcap. Sensor #4 has a male endcap and a terminating endcap.
  • It is important to note the orientation of the male outputs versus the female outputs. This can also be seen in Step 4.
  • Male outputs are generally on the outer sides of the machine. Any writing or labels on the bumpers need to be facing towards the ground.
  • Install Corner 1 sensor as shown
  • Install Corner 2 Sensor as shown
  • Install Corner 3 Sensor as shown
  • Corner 4 sensors is per installed.
 Note: orientation of the Endcaps, the length of sensors, and the orientation of the bumpers
Safety Sensors - Cable Routing and Testing
  • Connect sensor cables and route through the machine as shown
  • Use Cable ties and clamps to maintain the cleanliness of the cables.
  • The Enclosure Panels on Corners 2-3 have channels to route saftey sensor cables up through.
  • Use these channels to reduce visable wires.
Leveling
  • Adjust the leveling screws to raise the machine 3 1/2" (H) from the floor.
  • Readings are NTE 0.0002" over full travel.
