ST-40/40L/45/45L/50/55 - HPC-300/1K Installation - NGC - AD0437
Service Home How To Procedures ST-40/40L/45/45L/50/55 - HPC-300/1K Installation - NGC - AD0437
Recently Updated Last updated: 01/09/2019
AD0437
- Jump to Section - 1. Introduction 2. HPC Motor Drive PCB - Installation 3. HPC - Installation (5 steps) Back to Top
This procedure will show you how to install HPC-300/1K field install kit on a ST-40/40L/45/45L/50/55 lathes with the Next Generation Control.
  • 93-3846 ST-40/45 HPC-300 Field Install Kit
  • 93-3847 ST-40L/45L HPC-300 Field Install Kit
  • 93-3848 ST-50/55 HPC-300 Field Install Kit
  • 93-3853 ST-40/45 HPC-1K Filed Install Kit
  • 93-3854 ST-40L/45L HPC-1K Filed Install Kit
  • 93-3855 ST-50/55 HPC-1K Field Install Kit
Tools Required
Service USB key
Push [POWER OFF].
Set the main circuit breaker to the [OFF] position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Danger: If the vector drive voltage indicator light is on, do not touch the electrical components. Wait for the voltage indicator LED on the vector drive to go off completely.
Caution: When you handle a PCB, you must wear an Electrostatic Discharge (ESD) strap.
Do this step if you do not have a door panel installed in the control cabinet.
Open the control cabinet. Remove the cover for the I/O PCB.
Install these parts:
  • Use (2) screws [2] to install the top hinge plate [1].
  • Use (2) screws [3] to install the bottom hinge plate [4].
  • Use (4) screws [5] to install the (2) door brackets [6].
  • door panel [7]
Install these parts on the door panel:
  • (2) spacers [1]
  • motor-drive PCB [G]
  • (2) socket-head cap screws (SHCS) [2]
Connect the 33-1974 cable [H] to these locations:
  • P2 [3] on the motor-drive PCB (put the cable [H] through the left cable-carrier channel).
  • P10 [4] on the I/O PCB.
Note: This fan is only required on HPC-1K Kits.  Skip this step for HPC-300 Kits.
Install the bracket [2] for the fan assembly. Use the (2) 1 x 1/4" Phillips pan-head screws (PPHS) [1]. Make sure the arrows [3] on the fan assembly point in the correct direction.
Install the fan assembly [4] to HS6 [3] on the I/O PCB. Use the (2) 1/4" PPHS [5].
Connect the fan-assembly cable [7] to P11 [6] on the I/O PCB.
Connect the 33-0987B cable [I] to these locations:
  • P4 [1] on the motor-drive PCB (put the cable [I] through the top and right cable channels).
  • Connections 77, 78, and 79 [2] on the transformer (each wire has an identification label).
Connect the HPC extension cable [C] to P1 [3] on the motor-drive PCB.
Put the cable [C] through the top and right cable channels.
HPC - Installation
Remove the rear panels.
Route the HPC extension [1], vacuum sensor [2] cables.
Connect the HPC extension cable [1] to P1 on the HPC motor-drive PCB.
Connect the vacuum sensor cable [2] to P28 on the I/O PCB.
Route the purple tube [3] from the lube panel to the coolant tank area.  Make sure to leave enough slack at each end.
Install the receptacle end of the HPC extension cable to the receptacle bracket [4]. Use the twist lock mount and the screws.
Install the vacuum sensor cable to the receptacle bracket [5].
Remove the plug next to the standard coolant check valve.
Install the HPC check valve and flare fitting [1].
Remove the plug on the back of the coolant manifold.
Install the coolant pressure sensor [2].
Find the coolant pressure cable.  Remove the plug from the cable [3].
Connect the M12 coolant pressure connector to the sensor [4].
 Important: The coolant hose [5] installed must be rated to handle 1000 PSI if not contact the service department.
Turn off the air to the machine. Assemble the solenoid assembly [1].
Remove the plug from the air manifold. Install the solenoid assembly [2].
Trim the purple tube to the correct length. Connect the purple tube [3] to the air solenoid.
Connect the cable for the solenoid [4] to the connector panel label "HPC Auto Clean".
Install the HPC pump into the coolant tank.
Connect the HPC hose [1]  to the HPC pump.
Connect the purple hose [2] to the air fitting.
Connect HPC filter sensor [3] to the HPC pump.
Connect the HPC hose [4] to the coolant manifold.
Turn on the machine.
  • Login to the HAAS SERVICE PORTAL.
  • Download the HPC option configuration patch files.
     Note:  The option files will appear on the configuration download page after the HPC Kit has been ordered.  If the option does not appear contact the service department.
  • Load the option configuration patch file to the control.  Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
In [MDI] command: M88; (this m-code will turn on the HPC pump).
 Note:  To learn more about this M-code go to the Service section on www.haascnc.com.
Verify that the HPC pump turned on and that coolant comes out of the turret.
Check for leaks at the coolant manifold, coolant pressure sensor and hose fittings.
Install the covers.
