Control - 68K/Coldfire I to Coldfire II - Update - AD0249
Service Home How To Procedures Control - 68K/Coldfire I to Coldfire II - Update - AD0249
Recently Updated Last updated: 05/08/2025
AD0249
- Jump to Section - 1. Introduction 2. Install New PCB (4 steps) Back to Top
This procedure shows how to replace a 68EC030 (68K) [1] or Coldfire I [2] processor PCB with a Coldfire II processor PCB.
Before starting this procedure make sure to backup the machine, if possible. Refer to Machine Data Backup (Mill 15.xx and lower and Lathe 8.xx and lower).
This document applies to the following parts:
  • 93-3294410B - PCB Processor Coldfire II W/ 8MB Flash / 16MB BBU
Machine Compatibility:
  • Machine must have brushless motors and either a 68EC030 (68K) processor PCB with a 10" color LCD display or a Coldfire I PCB.
Install New PCB
Push [Power OFF] on the control.
Set the main circuit breaker to the OFF position.
Danger: If the vector drive voltage indicator light is on, do not touch the electrical components. The high voltage in the control cabinet can kill you. Wait for the voltage indicator LED to go off completely.
Caution: When you handle a PCB, you must wear an Electrostatic Discharge Strap (ESD).
Put an identification label on each cable that is attached to the PCB. This makes reinstallation easier.
Disconnect the cables.
Remove the Mocon, video and processor PCB's.
Install the Coldfire II (CFII) PCB.
Make sure the dip-switches are set to RUN and 10".
Connect the cables to the CFII PCB.
Install the Mocon PCB and connect all the cables that were disconnected.
You must load new software onto the Coldfire II PCB board.
Put a USB stick with the correct software into the USB port on the Coldfire II PCB.
Note: Do not put the USB stick into the port on the pendant. Use the port on the PCB board.
Note: Do not install software higher than M14xxx or L7xxx. Higher versions of software require a 15" LCB display.
To flash clear the memory on the PCB, follow these steps in order:
  • Push and hold [PRGRM CONVRS] while you push the [POWER ON] button.
  • Type FC .
  • Push [WRITE/ENTER].
  • Wait until the display shows the message "Flash Clear Complete".
  • Type M6000000 6FFFFFF. (M6 must be followed by 6 zeros, and 6FFFFFF must have 6 F's.
  • Wait until this message shows 3 times: "Memory Test Passed. Push Reset to Stop".
  • Push [RESET].
  • Wait until the display shows a blinking cursor (_>_).
To load the software, do the following sequence of steps:
  • Type the software version to load:
    • Mill - Type N M14xxx.bin. For example for mill 14.10C, you would type N M1410C.bin.
    • Lathe - Type N L7xxx.bin.
  • Type UF.
  • Push [WRITE/ENTER]. The display shows the message Loading 00XXXXX.
  • Wait until the display show Load Complete.
  • Press [POWER OFF].
  • Remove the USB stick from the Coldfire II PCB.
The machine then needs to be initialized. Follow these steps to initialize:
  • Push [POWER ON].
  • Put the machine in DEBUG mode.
  • Type the machine model. For example, on a VF-5 you would type VF5. Do not include the spindle taper.
  • Push [WRITE/ENTER] to start the machine again.
Note: Push a key at least once every 15 seconds to make sure the control does not turn off.
If you have backup files from the machine, you can follow these steps to restore them:
  • Push [LIST PROG].
  • Go to the tab that shows the device with your backup files.
  • Push [F4].
  • Push [MEM] and make sure that the correct files are on the disk.
  • Type the file name. Make sure to use the correct extension [1]. For example, 12345.PAR. Push [F3].
  • Wait until the screen shows Disk Done.
  • Make sure the parameters are correct. Refer to Parameter Checker Program - Menu Option (7).
  • Repeat this step again for these file types:
    • .ATM, ([CURNT COMDS] / Advanced Tool Management)
    • .SET, ([SETNG/GRAPH])
    • .VAR, ([CURNT COMDS] / MACRO).
Test the machine features to make sure they function properly.
