  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Gearbox - Oil Pump Replacement - VMC - 1989 to 1995 - AD0300
Service Home How To Procedures Gearbox - Oil Pump Replacement - VMC - 1989 to 1995 - AD0300
Recently Updated Last updated: 01/24/2019
AD0300
Applies to machines built from January 1989 to June 1995
- Jump to Section - 1. Introduction 2. Oil Pump Replacement (6 steps) Back to Top
This procedure tells you how to remove a magnet-drive oil pump for the gearbox and install an electric-drive oil pump.
Applies to kit PN: 93-1938, OIL PUMP ASSY, RETROFIT KIT EARLY VF
Remove the two oil port covers [1]. Use an oiler to add (2) drops of oil to each of the ports.
Put the oil port covers [1] back on the oil pump.
Use a pen or thin rod [2] to turn the fan [3] 2 full revolutions.
Remove the connecting pins [1] between the circuit breakers on the PSUP PCB.
Remove the circuit breaker from the location that has the label "CB4."
Install the BREAKER, 5A 2PL MED DLY [F] at CB4.
If the I/O PCB has a transistor at Q12:
Add the heatsink to the Triac at Q12 on the I/O PCB. If the Triac already has a heat sink, skip this step.
Cut the tab [1] off of the HTSNK T0-220 TOPCLIP BOARD MOUNT [G]. Make sure you fully remove the tab.
Push the heat sink over the Triac [2] at Q12 on the I/O PCB.
If the I/O PCB does not have transistor at Q12:
Discard the heatsink.
Remove the spindle head covers.
Remove the used oil pump [1] and the pump mount bracket.
Remove the 1/2" oil return hose. Remove the fitting [2] at the end of the return oil hose.
Do these steps if the machine has a heat exchanger at the top of the motor shroud:
  • Follow the (2) oil hoses from the exchanger to the nearest connectors. Disconnect the hoses.
  • Remove the heat exchanger.
Install the OIL PUMP ASSY [H]. Connect the pump power cable.
Connect the HOSE 3/8 OD PE CLEAR [D] to the top of the pump.
Put the FITTING, STRAIGHT-3/8 X STRAIGHT-3/8 PUSH TO CONNECT UNION [B] on the end of the 3/8" hose. Connect the fitting to the installed oil supply hose.
Connect the HOSE 1/2 OD PE CLEAR [E] to the right-angle fitting at the top of the pump.
Put the FITG PC1/2F NPT1/4M STR STL [C] on the end of the 1/2" hose. Connect the fitting to the installed oil return hose.
Connect the CBL950 OIL ADPTR QD-2X2MF [A] to the installed spade connectors on the mill.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
