      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Main Processor - Dual Battery Replacement Kit - Installation - CHC - AD0232
Service Home How To Procedures Main Processor - Dual Battery Replacement Kit - Installation - CHC - AD0232
Recently Updated Last updated: 11/23/2021
AD0232
Applies to machines built from: January, 1989
- Jump to Section - 1. Introduction 2. Installation - Processors with a Single Battery (3 steps) 3. Installation - Processor with Dual Battery (3 steps) 4. Dual Battery PCB - Battery Replacement (2 steps) Back to Top
This procedure will show you how to install a Dual Battery kit on a machine or a simulator with a Classic Haas Control.
If the battery was replaced on a simulator it is possible that you will need to recover the software configuration.  Refer to the following procedures:
  • Maincon - Dual Boot Simulator - M17/18.xx / L10/11.xx - Software Recovery - CHC
  • Cold Fire 2 - Dual Boot Simulator - M16.xx / L09.xx - Software Recovery - CHC
If the procedures above do not apply to your simulator, contact your local Haas Factory Outlet for support.
This Procedure Applies to these Parts:
  • 93-32-4307 PCB, DUAL BATTERY REPLACEMENT KIT (BATTERIES NOT INCLUDED)
 Caution: When you handle a PCB, you must wear an Electrostatic Discharge (ESD) strap.
The machine data can be lost in the battery replacement process. Backup your files.
Note: This does not apply to a control simulator.
Install a VELCO STRIP [B] on a clean space [1] inside the control cabinet as shown.
Note: If installing the battery on a simulator find a spot inside the simulator enclosure.
Attach the DUAL BATTERY PCB [A] to the VELCRO STRIP [B]. If they are not installed, install the (2) batteries [2]. Use the (2) clips [3].
Connect the DUAL BATTERY PCB [A] cable [4] to the P1 connector on the processor PCB.
Note: Cold Fire 1 processors (32-4401) do not have the P1 plug for this kit.  You would need to solder the wires directly to the PCB.  Where the black cable connect to (-) negative and the red cable goes to (+) positive.
 Note: Remove the PCBs to get access to the processor PCB as necessary. Be sure to label the cables you disconnect to assist in installation.
Cut the old battery leads [2]. Use a pair of cutters [1].
Discard the old battery.
Install the PCBs and the cover as necessary.
Remove the two batteries.  Solder a jumper wire across (-) to (-) and (+) to (+) as shown on the illustration.
Connect the DUAL BATTERY PCB kit into J6.
Mount the DUAL BATTERY PCB kit to the wall of the electrical control cabinet.
Push [POWER OFF]. Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
One battery must remain on the dual battery PCB at all times. Replace the batteries one at a time.
Remove the clip [1] that holds the battery [2] to the dual battery PCB. Replace the removed battery [2]. Install the clip [1] onto the replaced battery [2].
Repeat the instructions for the second battery [3].
Set the main circuit breaker to the ON position. Push [POWER ON].
If the machine data is lost, use the backup file you created in step 1. The document you used for backup instructions also explains how to reload the data.
