  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Rotary - TR/TRT/T5C - Platter - Tool Change Offset - Adjustment
Service Home How To Procedures Rotary - TR/TRT/T5C - Platter - Tool Change Offset - Adjustment
Recently Updated Last updated: 02/19/2021
Tilting Platter - Offset Adjustment
Push [ZERO RETURN]. Push [A].
Note: For NGC: If you get Alarm 5.165, refer to the Axis Grid Offset - NGC procedure to set the grid offset.
Note: For CHC: If you get Alarm 168, refer to the Axis Grid Offset - CHC procedure to set the grid offset.
Put the magnetic base of a dial indicator on the spindle head.
Jog the X axis to center the platter on the spindle. Jog the Y and Z axis until the indicator is above the platter edge. Make sure you can indicate the full diameter from front to back.
Set the indicator to zero. Indicate the platter or collet face along the Y Axis.
Classic Haas Control:  Adjust Parameter 212 in small increments in the positive (+) or negative (-) direction to adjust the flatness.
Do these steps again until the error is less than 0.0003" (0.008mm).
Next Generation Control:
Go to [Settings], Rotary tab.
Press the [Insert] button to set the TC offset.
Caution:  Do not press the [F3] button.
Verify that rotary zero returned to the indicated position.
Test the Travel Limits
Release [EMERGENCY STOP].
To make sure the travel limits of the A axis are correct handle jog in the positive and the negative direction. Make sure the movement stops at 120 degrees in each direction.
Caution: Stop jogging the axis if the A axis (tilt) moves more than 120 degrees. Make sure that Setting 30 4TH AXIS ENABLE and Setting 78 5TH AXIS ENABLE are correct. If the settings are correct and the A axis (tilt) still moves more than 120 degrees, speak to your Haas Factory Outlet (HFO).
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
