ST-20/30/L - Tailstock Forced Lubrication - Field Installation - AD0804
Service Home How To Procedures ST-20/30/L - Tailstock Forced Lubrication - Field Installation - AD0804
- Jump to Section - 1. Introduction 2. Tailstock - Removal (8 steps) 3. Installation (10 steps) 4. Tailstock Hose Routing (4 steps) 5. Verification Back to Top
Recently Updated Last updated: 03/31/2025
AD0804
This procedure shows how to field install forced lubrication on the tailstock for ST-20/30/L machines with an ACME Screw.
Haas recommends this conversion for all tailstock lathes to avoid lubrication inconsistencies on B-axis linear guides. The previous revision of this system relied on gravity to feed HLG to the linear pads but now the system is automated and controlled by the machine for ease of use.
This procedure applies to the following kit:
  • 93-4616 - TAILSTOCK ACME SCREW FORCED LUBE SVC KIT
Tools Required:
  • A lift device capable of handling approximately 450 lbs.
 CAUTION: You should not do machine repairs or service procedures unless you are qualified and knowledgeable about the processes. Serious damage to the machine components can result in costly repairs. The service technicians at your Haas Factory Outlet (HFO) have the training and experience, and are certified to do these tasks safely and correctly. The repair and service work performed by your HFO is protected with a limited warranty.
Tailstock - Removal
Jog the Z-axis away from the spindle towards the right side of the machine.
Jog the X-Axis and Y-Axis (if available) away from the tailstock, this will put the turret at the top right corner of the machine.
Press [E-STOP].
Remove reservoir [1].
Remove the reservoir bracket [2].
Remove the brass fitting [3].
Remove the fittings from the manifold [4].
With the chuck removed, move the tailstock as close to the spindle as possible.
NOTE: Tailstock can be jogged to get clearance to remove the quill assembly.
Remove the bolts [1] to remove the quill assembly [2].
Remove the (4) bolts and washers [1] that hold the tailstock assembly to the riser plate.
Feed the lift strap through the tailstock and use lifting device [1] to lift the tailstock.
 NOTE: Take note of the placement of the shims.
Remove the shims and store them in a safe place. They will be used for reinstalling the tailstock.
 NOTE: Lifting device is needed to remove the riser plate.
Remove bolts to remove the Riser Plate [1].
Remove ACME Ballscrew Cover [2].
Remove the Lubrication Line Assembly [3].
Disconnect the copper tubes from the ballnut and linear guide trucks [3]. Use shop air to blow the remaining HLG grease out of the copper tubes.
 NOTE: Wiper may need to be removed to facilitate the removal of the copper line fittings from the ballnut. Take note of the orientation of the wiper for installation later on in the procedure.
Verify that the restrictor is present in the fittings.
Remove non-restricted fittings from the trucks and replace them with the restricted fittings.
 NOTE: When installing the restrictor fittings, be sure to be gentle as the fittings are fragile and can damage if not handled carefully. It is required to torque them to 12 in-lbs (1.36 Nm).
Install the Lubrication Line Assembly provided in the kit.
 NOTE: If wiper was removed to facilitate the removal of the copper line fittings from the ballnut, install the wiper to its original placement and orientation.
Screw on the (4) bolts from the riser plate to the nut housing.
Snug the (24) bolts from the riser plate.
Place the shims back where it was marked.
Snug the green circled fasteners and leave the red circled fasteners loose.
Squaring Tailstock Riser Plate
Mount the magnetic base to the turret.
Release [E-STOP].
Indicate the back face of the riser plate by jogging the Z-Axis.
Adjust the riser plate until the indicator reads within the tolerance.
 NOTE: .001"
Press [E-STOP].
Torque the 24 bolts to spec that mount the riser plate to the linear guide trucks in an "X" pattern as shown.
 NOTE: Verify riser plate squareness afterwards.
Lift the tailstock by using a strap that goes through the bore.
Clean the mating surfaces at the bottom of the tailstock.
Install the tailstock using the (4) bolts.
Clean the bore of the tailstock and the quill assembly prior to installation.
Install the quill assembly [1] using the bolts [2].
Install the elbow fitting to the manifold [1].
Connect the hose [2] to the adapter fitting.
Route the hose [1] so that is goes through the grommet [2].
 NOTE: Cable carrier cover was hidden to show the grommet [2]. It will need to be removed to pass the hose through the grommet [2].
 IMPORTANT: Make sure to leave some slack on the hose so that the tailstock can move without any tension on the hose.
Once the hose [1] is through the grommet, route the hose through the cable covers.
 NOTE: Cable Covers need to be removed to route the hose.
Feed the hose through the top opening of the Lube Cabinet and connect it to the brass fitting [2].
Connect the clear hose [3] to the brass fitting [2].
 NOTE: Cut the clear hose so that there is enough length to connect to the fitting [4] that goes to the check valve manifold.
Connect the hose to the brass fitting [4] that connects to the check valve manifold.
Verification
To check that the tailstock is aligned with the rest of the axis, refer to these documents.
  • ST Lathe Alignment - Indicating Zones
  • Field Service Lathe Level and Alignment Checklist - ST and DS
  • ST - Tailstock Parallelism to Z-Axis Correction
  • ST - Tailstock Concentricity to Spindle Correction
Axis Lubrication System - Prime and Test
Conduct the "Axis Lubrication System - Prime and Test" section found in the Haas Axis Lubrication Oil - Reservoir Refill - AD0630 procedure.
