TL-1/2 - ATT-4/8 Turret - Installation and Alignment - AD0304
Service Home How To Procedures TL-1/2 - ATT-4/8 Turret - Installation and Alignment - AD0304
Recently Updated Last updated: 12/17/2024
AD0304
Applies to machines built September 2014 and after
- Jump to Section - 1. Introduction 2. Installation (8 steps) 3. Test (1 step) 4. Turret - Alignment (3 steps) Back to Top
This procedure tells you how to install a ATT-4/8 turret on a TL-1 or TL-2 lathe.
Software Requirements:
  • Classic Haas Control (CHC) - Software version 11.24A or higher.
  • Next Generation Control (NGC) - Software 100.17.000.2040 or higher.
Tools Required
  • 0.0005" Dial Indicator with Magnetic Base
  • Service USB key (NGC only)
Document Applies to these kits:
CHC Machines:
  • 93-2228 - TL-1/2 ATT4 Inch - CHC
  • 93-2229 - TL-1/2 ATT4 Metric - CHC
  • 93-1000280 - TL-1/2 ATT4 Inch - CHC - Sigma 5
  • 93-1000281 - TL-1/2 ATT4 Metric - CHC - Sigma 5
  • 93-1000282 - TL-1/2 ATT8 Inch - CHC - Sigma 5
  • 93-1000283 - TL-1/2 ATT8 Metric - CHC - Sigma 5
NGC Machines:
  • 93-1000633 - TL-1/2 ATT4 Inch - NGC - Sigma 7
  • 93-1000632 - TL-1/2 ATT4 Metric - NGC - Sigma 7
  • 93-1000634 - TL-1/2 ATT8 Inch - NGC - Sigma 7
  • 93-1000640 - TL-1/2 ATT8 Metric - NGC - Sigma 7
Move the cross-slide approximately 10" (25 cm) away from the spindle. Move the cross-slide forward to get access to the way cover.
Use the air hose to clean the table and the way cover.
Push [POWER OFF].
Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Disconnect the air supply.
Danger: If the 320V Power Supply High voltage indicator light is on, do not touch the electrical components. The high voltage in the control cabinet can kill you. Wait for the 320V Power Supply voltage indicator LED to go off fully.
Remove the cover [1] on the top of the electrical cabinet.
Open the control cabinet door.
Install the air solenoid [2] into the air manifold. Connect the air hoses to the air fittings [3].
Route the two small airlines through the cable channel into the opening at the top of the control cabinet [4].
Route the exhaust hose to the bottom of the electrical cabinet and secure it in place with a zip tie [5].
Put the air solenoid cable through the cable channel  and connect it [6].
  • CHC:  Connect the solenoid cable to the extension cable label " TC UP SOL" that came in the kit and plug it into the I/O PCB P55.
  • NGC: Connect to cable label "TC UP SOL inside the cable track.
Install the 30-Amp servo amplifier [1] into the amplifier bank section that has the label "Tool Turret."
Route the servo motor power and encoder cables from the top of the electrical cabinet [2].
Connect the power wires to the high voltage terminals on the amplifier [3]:
  • red to RED
  • white to WHT
  • black to BLK
Install the jumpers [4] from the nearest amplifier to the 30-Amp servo-amplifier:
  • Connect the black wire to -H.V..
  • Connect the red wire to +H.V..
Connect the ground stud [5] to the chassis.
Install the ferrite filter (NGC kits only) to the motor power cables.
Connect the current command cable [6] to the connector at the top of the amplifier to Maincon.
  • CHC: P5
  • NGC: Channel 7, P7
Connect the encoder cable to the Maincon [7].
  • CHC: P9
  • NGC: Channel 7, P23
Remove the cover [1] from the top of the enclosure. This gives you access to the opening.
Put the turret power cable, encoder cable [3] and the air tubes [2] through the opening in the cabinet.
Put the air tubes [2] and cables [3] into the coolant hose conduit [4].
Remove the cross-slide way cover [4].
Remove the cover plate [9] for the coolant hose. Remove the breakout tab [8] from the cover plate.
Remove the coolant hose assembly [7].
Install the ATT-4 turret [1] onto the (2) outer holes [5] of the cross-slide.
Install the ATT-8 turret [2] onto the (2) inner holes [6] of the cross-slide.
Keep the screws sufficiently loose for turret alignment.
Remove the servo-motor cover [3].
Pull the cables and air hoses from the coolant hose conduit [3].
Install the split conduit with the cables and hoses into the clamp [8].
Connect the (2) air tubes to the (2) air fittings [4].
Note: Add dielectric grease to all connections. See Electrical Component Corrosion Prevention Procedure for more information.
Connect the power cable [5], and encoder cable [7] to the motor. Connect the home switch cable [6].
Note: Make sure all electrical connections are made inside of the motor compartment.
Install the cover plate [9]. Install the cross-slide way cover [2].
Install the cover for the servo-motor [1].
Install the cover for the upper cable channel and the top of the enclosure.
Install the extension tube [2] and the coolant hose assembly [1].
Connect the air supply.
Set the main circuit breaker to the ON position.
Push [POWER ON].
For Classic Haas Control:
  • Set Setting 7, Parameter Lock, to OFF.
  • Set Parameter 710, Tool Changer Type, to 4.
  • Change Setting 113, Tool Change Method, to AUTO.
  • Record the parameter values on the identification plate [3].
  • Put these values into Parameter 128, and Parameter 212.
For Next Generation Control:
  • Login to the Haas Service Portal.
  • Download the option configuration patch files.
  • Load the option configuration patch file to the control.  Refer to the Next Generation Control - Configuration File - Download/Load procedure.
  • Insert the Service USB Key and go into Service Mode.
  • Set Parameter 618, Tool Changer Carousel Type, to 2.
  • Set Parameter 710, Tool Changer Type, to 34.
  • Set the turret's tool change offset. Refer to the TL-1/2 TT4 Tool Changer Offsets NGC procedure for more information.
Test
Operate this code in MDI mode:
For the ATT-4:
T1;
T2;
T3;
T4;
M99;
For the ATT-8:
T1;
T2;
T3;
T4;
T5;
T6;
T7;
T8;
M99;
Important: Once clamped at each tool #, verify that the load is always below 5%.
  • Run the program for approximately 1 minute.
  • Throughout the execution of the program, verify proper clamping / unclamping of the turret, and tool # position as commanded by the program.
  • If it does not operate properly, ensure that the parameters were set correctly per the procedures above.
  • If tool changes are correct, but loads are above 5%, check the tool changer for any mechanical binding.
Turret - Alignment
Make sure the mounting screws are sufficiently loose to do the alignment procedure.
Put the tip of the indicator on the horizontal surface [1].
Jog the X axis to measure along the horizontal surface.
The error should be less than 0.002" (0.05 mm).
If the error is more than 0.002" (0.05 mm) across 5.5" (140 mm) of travel, use shims [2] to adjust the height of the turret. Use shims as necessary.
Put the indicator tip against the vertical surface [1].
Jog the X axis to measure along the vertical surface.
The error should be less than 0.001" (0.025 mm).
If the error is more than 0.001" (0.025 mm) across 5.5" (140 mm) of travel, lightly tap the base of the turret with a soft mallet.
Align the turret with the spindle centerline:
  • Install a toolholder [1] with a 1" (25.4 mm) bar [2] at tool position 1.
  • Attach an indicator [3] to the spindle.
  • Jog the X Axis until the bar [2] is at the center of the spindle.
  • Turn the spindle 360 degrees. Measure around the diameter [4] of the bar.
If the radial error is more than 0.001" (0.025 mm), use shims to adjust the height of the turret. Use shims as necessary.
Torque the (2) screws [5]. Refer to Haas Fastener Torque Specifications. Use the value for steel.
Make sure that the alignment of the turret is correct. If it is not, do this alignment procedure again.
