  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
      • Compact Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Lathe Turret Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
TRT Rotary Air Clamp Provision - Installation - AD0524
Service Home How To Procedures TRT Rotary Air Clamp Provision - Installation - AD0524
Recently Updated Last updated: 04/12/2022
TRT Rotary - Air Clamp Provision - Installation
AD0524
This procedure will explain how to install the Rotary air union on the following units:
  • TRT160 built after 8/16/2019
  • TRT210 built after 03/16/2020
  • TRT310 built after 10/01/2021
NOTE:  The TRT160, TRT210, and TRT310 must have the motor cover with the AUX 1 and AUX 2 port on the rotary axis.
Machine Requirements:
  • Next Generation Control
TRT160
  • AIR-CLAMP-PROV-160  Air Clamp Provision only.
  • 93-1000427  AIR CLAMPING PROVISION TRT160
TRT210
  • AIR-CLAMP-PROV-210    Air Clamp Provision kit only.
  • AIR-CLAMP-PRO-MANU Manual Air Clamp Provision kit.  This kit comes with a manual switch
  • AIR-CLAMP-PRO-AUTO   Automatic Air Clamp Provision kit.  This kit comes with a foot pedal switch.
TRT310
  • AIR CLAMP MANU 310 Manual Air Clamp Provision kit.  This kit comes with a manual switch
  • AIR CLAMP AUTO 310 Automatic Air Clamp Provision kit.  This kit comes with a foot pedal switch.
  • 100MM AIR VISE-MNL 100mm air vise to use with manual switch
  • 100MM AIR VISE-AUT 100mm air vise to use with foot pedal switch.
 Warning: Zero return the unit before installing the air clamp union assembly [1].
Use the SHCS 10-32 [2] to install the assembly onto the unit.
NOTE: The TRT160  will have x4 10-32 screws, while the TRT210 and TRT310 will have 3.
TRT160 and TRT210
The air clamp union should be installed in the correct orientation as shown. Auxiliary port 1 is denoted as [1] and auxiliary port 2 as [2].
TRT310
For TRT160's with equally spaced platter bolts, use the shown orientation with the aux 1 denoted as [1] and aux 2 denoted as [2].
Move the NPT plugs from the auxiliary ports below the unit [1] to the ports shown in position [2].
Install the copper lines and fittings as shown.
[1] COPPER TUBE 2 PORT UNION AUX 2 TRT210
[2] FITG LUBE COMP NUT BIJUR-M 5/32 (2x)
[3] FITG LUBE COMP SLEEVE 5/32 BRASS
[4] FITG LUBE BIJUR-F NPT1/8M STR BRASS
Manual - Air Clamp Provision
Follow this step for the Manual Air Clamp Provision Option.
Install the air switch [1], the switch can be mounted on the inside or outside of the machine via magnet.
Connect the air supply [3] to the air switch [1].
Connect the air lines from the swtich [1] to the unit [2].
Note: The AUX 1 port will act as clamp and the AUX 2 port will act as unclamp.
Automatic - Air Clamp Provision - Installation
Follow these steps for the Automatic Air Clamp Provision Option.
Connect the SS braided hoses [1] from the solenoid assembly to the 90° compression fittings [2] at AUX 1 and AUX 2.
Note: The red zip tie denotes clamp and the green zip tie denotes unclamp.
Solenoid 30-13112 UNCLAMP/CLAMP:
Warning: E-Stop and turn off the machine before any electrical installation
Remove a NPT plug from the air manifold inside the lubrication cabinet and install the solenoid[1] to the air manifold into the location APC DOOR INTERLOCK/PROGRAMMABLE AIR shown on the AIR - LUBRICATION SYSTEM - PICTORIAL.
Connect the red hose at the location with the red ziptie and connect the green hose at the location with the green ziptie.
Note: The ports that these hoses are installed to will determine if the vise remains clamped when power is cut to the machine. Test at end of installation.
Plug cable 33-0631 in at P50 on the I/O board. Plug the other end of the cable into the APC Door Interlock/Programmable Air location on the solenoid bracket.
Plug the solenoid into 33-0631 at the APC Door Interlock/Programmable Air molex connector.
Connect cable 33-0732 onto the pressure switch on solenoid 30-13112. Plug cable 33-0738 into P13 on the I/O PCB and connect the the other end to cable 33-0732.
Drill a 5/8" hole in the front skirt to install the foot pedal cable.
Route cable 32-1390 from P14 on the I/O PCB to the front skirt of the machine to connect to the foot pedal.
Note: To install the Pnuematic Vise, refer to the TRT Pneumatic Vise - Installation procedure.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
