32mm Ballscrew Bearing Pack Retrofit Kit Installation AD0461
Service Home How To Procedures 32mm Ballscrew Bearing Pack Retrofit Kit Installation AD0461
Recently Updated Last updated: 03/25/2025
32mm Ballscrew Bearing Pack Retrofit Kit - Installation
AD0461
- Jump to Section - 1. Introduction 2. Installation - Non-Integrated Bearing Housing (3 steps) 3. Installation - Integrated Bearing Housing (2 steps) Back to Top
The 30-0154 32mm Ballscrew Bearing Pack is being replaced by the 51-0268A Cartridge Bearing. Part number 93-2901, SERVICE KIT REPLACE 30-0154 WITH 51-0268A, was created to include the bearing and bearing fillers that prevent bumper and ballscrew damage, the spacer is included but may not be needed, the new P/N for the spacer is 51-0240. The kit will include two bearing fillers but only one will be used depending on the housing.
Note: If your machine is already fitted with a cartridge bearing, this kit does not apply. Simply replace the cartridge bearing with 51-0268A, reuse the bearing spacer if needed, and use the bearing filler original to your machine.
Use the links as additional references for Spacer Installation, Ballscrew Bearing Identification, and Ballscrew - Installation Tools and Torque Specifications.
Ballscrew spacer- installation
Ballscrew Bearing Combination
In assemblies where the bearing housing is not integrated into the main casting, use bearing filler PN 28-0371. The o-ring (PN 57-0721) is separate in the kit and should be installed in the groove on the bearing filler.
The filler should be installed from the side shown. If it is installed from the opposing side, there is a chance that the o-ring may shear. This could cause the filler to come loose during operation.
Lubricate the o-ring and install the bearing filler [1] into the bearing housing. You will need to use a 2" diameter plastic or wood tool [2] and lightly tap with a mallet. Tap the filler about a half inch into the bore as shown. The o-ring will hold the filler in position.
 Seat the cartridge bearing [3] with a firm push. Be sure the bearing filler is pushed against the bearing. Bearing is shown before being seated.
If your bearing housing has the groove feature highlighted in red, you will tap the bearing filler into position using the same method as step 2.
The only difference is that you will drive the bearing filler in until the o-ring seats inside of the groove. The bearing filler may be loose inside of the bore. This is correct, as the o-ring is sufficient to hold the bearing filler in place.
In assemblies where the bearing housing is integrated into the main casting, use bearing filler PN 28-0370. The o-ring (PN 57-0721) is separate in the kit and should be installed in the groove on the bearing filler.
Note: Integrated assemblies include TM-1/2 columns, DT/Mini Mill columns, TM tables, and Mini Mill family saddle
Lubricate the o-ring and install the bearing filler [1] into the casting. You will need to use a 2" diameter plastic or wood tool [2] and lightly tap with a mallet. Tap the filler about a half inch into the bore as shown. The o-ring will hold the filler in position.
 Seat the cartridge bearing [3] with a firm push. Be sure the bearing filler is pushed against the cartridge bearing. Bearing shown before being seated.
Note: DT series column shown.
For reference, this is the same procedure shown on a TM series table.
For reference, this is the same procedure shown on a Mini Mill saddle.
