CHC - Maincon PCB - Replacement - AD0312
Service Home How To Procedures CHC - Maincon PCB - Replacement - AD0312
Recently Updated Last updated: 04/29/2025
Classic Haas Control - Maincon PCB - Replacement
AD0312
- Jump to Section - 1. Introduction 2. Replace Maincon Board (2 steps) Back to Top
This procedure shows how to replace the Maincon PCB on a Classic Haas Control (CHC) machine.
Note: Before following this procedure make sure to make copies of the machine data files. Refer to the Machine Data Backup (Mill16.xx and higher, and Lathe 9.xx and higher) procedure for how to make copies.
This document applies to the following service kits:
  • 93-32-4301E - Maincon Processor PCB
  • 93-32-4301F - Service Kit Coldfire Maincon
The following tools are required for this processor:
  • USB memory stick
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Caution: Before you touch a PCB you must put an Electrostatic Discharge (ESD) strap on your wrist to prevent the PCB from being damaged.
Disconnect all cables [1] from the used Maincon PCB [2].
Note: Some machines with fifth-axis enables have a Mocon PCB installed. If the Mocon PCB is installed in front of the Maincon PCB, mark the locations of all cable connections and remove the Mocon PCB.
If the Maincon PCB has standoffs, remove them. Then remove the used Maincon PCB [2].
If you have a Mocon PCB, install it before you install the Maincon PCB.
Install the new Maincon PCB [3]. Connect the cables [4] that you disconnected from the used Maincon PCB [2].
After all the cables are reconnected, turn the main breaker to the ON position.
Press [Power On] on the control pendant to power up the machine.
The Maincon PCB comes with the latest software at the time of packaging. The software needs to be initialized.
Refer to the below procedures for initializing software:
  • Maincon Control Software Initialization (Mill Version 17 and Lathe Version 10)
  • Maincon Control Software Initialization (Mill Version 18 and Lathe Version 11)
If the machine is a Lathe refer to the following procedures:
  • Maincon Control Software Load (Mill VER17 and Lathe VER10)
  • Maincon Control Software Load (Mill VER18 and Lathe VER11)
Note: Do not install 18.xx series software on a Mill that had 17.xx series software. Do not install 11.xx series software on Lathe that had 10.xx series software.
If you have any problems during the replacement or when updating software refer to: Classic Haas Control - Maincon / Software Update Troubleshooting Guide.
 NOTE:  This procedure can only be performed by a Haas certified service technician.
Instructions for Maincon Control Software - CHC are available on HBC in the Service section -> Utilities -> Documents & Software ->
