Red Grease to Haas Axis Lubrication Oil - Conversion - AD0659
Service Home How To Procedures Red Grease to Haas Axis Lubrication Oil - Conversion - AD0659
Recently Updated Last updated: 01/30/2023
AD0659
Important: CHC Mills will need software M18.28 or higher and CHC Lathes will need software L11.24 or higher.
Service Techs performing the software update on CHC Mills should view this service news on the HSG site.
This procedures tells you how to convert a machine with red SHC 007 axis lubrication grease to Haas Axis Lubrication Oil. The Haas Axis Lubrication Oil system uses a different reservoir assembly and different fittings at the linear guide trucks and ballscrew.
This procedure applies to the following service kits:
  • 93-2755A: HAAS AXIS LUBE OIL RETROFIT KIT
  • 93-3610: HALO SVC KIT CHECK VALVE
Note: Every Lathe will need at least one (1) of kit 93-3610. Lathes that also have a Y-Axis will need to order two (2) of kit 93-3610.
Note: UMC's will now need three (3) of kit 93-3610 to add check valves to all of the lubrication lines.
Important: Before ordering any check valves kits (93-3610) please verify the machines configuration in the images in the Install New Reservoir section below.
 IMPORTANT: If the machine has SKF branded linear guides contact Haas Service.
Required Cable:
A low grease sensor cable (CBL500 LOW GREASE SENSOR) must be ordered with 93-2755 from the table below.
Note : The cable required is the A version of the cable that is currently installed on the machine (Applicable to machines built before 3/17/15).
Part Number Machine Compatibility Length (ft)
33-10044A VF-1
OL-1
ST-50/55
11.7
33-0240A ST-10/20/20Y/30/30Y
DS-30/30Y
OM-1
EC-400/400P/500
16
33-0289A ST-40/40L 24
33-0389A GR510/712 40
Prerequisites:
The machine must have software version M18.28 or higher or L11.24 or higher. Change Setting 252 to a value of 3. Make sure to change the parameter values in the table below.
Parameter Name Value
810 AXIS LUBE TYPE 5
811 AX INTRVL METERS Use the Parameter Checker to find the value for your machine.
815 AX LUBE INPUT 25
816 AX LUBE OUTPUT 52
861 AX LUBE TIME INTRVL 480
1374 AX LUBE TYPE 5 MAXIMUM PRESSURE RISE TIME (ms) 3000
1375 AX LUBE TYPE 5 MINIMUM PRESSURE DURATION (ms) 15000
1401 Power-On Axis Lubrication Time Interval 12
Conversion
Remove the existing lubrication system.
Remove the waycovers necessary to get access to the axis manifold [3] and ballscrew [2] for each axis.
Get access to the lubrication housing box [1] between the column and base casting.
Disconnect the copper tubes from the ballnut and linear guide trucks [4]. Use shop air to blow the remaining red grease out of the copper tubes.
Remove and discard the grease tubes to each axis and everything inside the lubrication housing box [1].
Install fittings and new reservoir.
Install the brass nipple fitting [1], check valve [2], and hose fitting [3] to one of the ports on the grease manifold.
Install the other two hose fittings [3] to open ports on the oil manifold.
Install the two plugs [4] in the remaining two open ports.
Remove the red grease reservoir assembly.
Install the Haas Axis Lube Oil reservoir assembly and air tube. Use the bracket [5] to install the assembly to the lubrication cabinet. Install the metal reservoir with Haas Axis Lube Oil [6].
Connect the pressure switch cable to the pressure switch behind the oil manifold.
Install new clear lubrication tubes.
Install new tubes from the ports [1] on the oil manifold to each axis.
Note: The tube that supplies the vertical axis must be plugged into the port with the check valve. This is the z-axis in a VF or MM, the y-axis in an EC, or the x-axis in an ST.
Connect the air hose [2] from the solenoid on the air manifold to the Haas Axis Lube Oil reservoir assembly.
Install the banjo and restrictor fittings.
Remove the fittings at the ballscrew and at each linear guide truck.
Install the banjo fitting [1] at the ballscrew port. Torque the banjo fitting to 10 in-lbs. Be very careful here; if you exceed 10 in-lbs you will break the banjo bolt.
Install the restrictor fittings [2] at each linear guide truck port.
Torque the restrictor fittings as follows:
  • For linear guide brand Rexroth: 15 in-lbs
  • For linear guide brands INA, NSK, and THK: 12 in-lbs
Fill the new reservoir [1] with the Haas Axis Lubrication Oil to about 1/2" (13 mm) below the threads on the reservoir.
Follow this step for Mills
Note: UMC's will now need three (3) of kit 93-3610 to add check valves to all of the lubrication lines, the check valves are grey in image [2] to show where they need to be added.
Mills with a SMTC will need to add a .02" orifice (shown as the red component in the images) to their lube lines on the oil reservoir. Use the numbered images and the following list to see where the orifice needs to be added on the following machines:
  1. SMTC: VF - 1-9, DT, DM, VR-8, VM - 2/3/6, VC-400
  2. UMC 350-1600
  3. EC-400/500/500-50T/630/630-50T
  4. GM-2, GM-2-5AX
  5. VF - 10/11/12/13/14, VR - 9/10/11/12/13/14
  6. VMT-750
  7. VS-1/3
Note: A small amount of SMTC's do not have a servo carousel and therefore will not need the additional orifice. This means that any mills that only have 3 grease lines on the lubrication reservoir do not need the additional orifice.
Note: Not all lubrication configurations are shown, only configurations that are adding new fittings in the conversion process are shown for reference on where the new fitting goes.
Follow this step for Lathes
 Note: Tail stock fittings are shown as the blue component in the images.
Lathes with a C-Axis will need to add a .02" orifice (shown as the red component in the images) to their lube lines on the oil reservoir. Lathes will also need to add an extra check valve and nipple fitting to the X-Axis and the Y-Axis if it has one (the X and Y axes are labeled in the image to the right). Use the numbered images and the following list to see where the orifice and fittings need to be added on the following machines:
8. Longbed & Non-longbed: CL, ST-10/15/20/25/28/30/35
9. Y-Axis Longbed & Non-longbed: ST-10Y/ 15Y/20Y/25Y/28Y/30Y/35Y, ST-10LY/15LY/20LY/25LY/28LY/30LY/35LY
10. C-Axis Longbed & Non-longbed: ST-10/ 15/20/25/28/30/35
11. C-Axis & Y-Axis Longbed & Non-longbed: ST-10Y/ 15Y/20Y/25Y/30Y/35Y
12. Longbed & C-Axis & Y-Axis & Sub-Spindle: DS-30Y, ST-10LY/ 15LY/20LY/25LY/28LY/30LY/35LY
13. Longbed & Tail Stock: ST-40/40L/45/45L/50/55
14. Longbed & C-Axis & Tail Stock: ST-40/45/50/55
15. Longbed/Non-Longbed & Tail Stock: ST-30/35
16. Longbed/Non-Longbed & Tail Stock & Y-Axis: ST-30Y/35Y
Oil Reservoir - Prime and Test
Press [PARAMETER DIAGNOSTIC] (2) times to show the diagnostics page.
Press [CANCEL].
Go to the [LUBE] tab.
Press [WRITE/ENTER] .
Press [F2] to start the Axis-Lubrication Test.
Perform the Axis-Lubrication Test again until you no longer get axis lubrication alarms. Wait a minimum of (1) minute between Axis-Lubrication Test cycles.
Check the level of the oil in the reservoir.
If the oil lines were nearly empty, it may be necessary to refill the axis-lubrication reservoir after you purge the lines of air. Pour the oil into the reservoir: to about 1/2" (13mm) below the threads on the reservoir.
