  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
C Axis - Grid Offset - Adjustment - ST - SL
Service How To Procedures C Axis - Grid Offset - Adjustment - ST - SL
Recently Updated Last updated: 11/27/2018
- Jump to Section - 1. ST/SL Lathe - C Axis - Grid Offset - Adjustment (16 steps) Back to Top
Remove the enclosure panels in the order shown.
Disconnect the air supply [1] to the actuator block for the C axis.
Install the air regulator and cutoff valve on the actuator air supply hose.
Connect the air supply and set the regulator.
 Note: For an SL Lathe, set the air pressure on the regulator to 45 PSI. For an ST Lathe, set the regulator to 85 PSI.
Go into DEBUG mode.
Change Parameter 517 C GRID OFFSET to 0.
[ZERO RETURN] the C Axis.
Set Parameter 278:26 C AXIS DRIVE to 0.
Set Parameter 498:3 C AXIS DISABLED to 1.
Type M19 in MDI mode.
Press [CYCLE START].
Open the cutoff valve to engage the actuator block.
The C-axis gears must engage correctly. Use an inspection mirror to see the gears engage. Turn the C-Axis motor with your hand. Turn the motor gear until the gears align. Turn the C-Axis motor gear until they engage.
Press [POSIT].
 Note: On an ST-40, you cannot rotate the gears with your hand. Put a flat-head screwdriver through the hole. Use the screwdriver to turn the motor. Turn the motor until the gears align.
Navigate to the Pos-Raw Dat 1 data page.
Record the value in the C AXIS ACTUAL column. For Sigma-1 motors, the value is between +/- 1260. For ST-40 and larger with Sigma-5 motors, the value is between +/- 50400. For all other Sigma-5 lathes, the value is between +/- 10080.
Set the value in Parameter 517 C GRID OFFSET. Use the recorded value in the C AXIS ACTUAL column.
For this example, the value is 261.
Release the air from the actuator block.
Set Parameter 498:3 DISABLED to 0.
[ZERO RETURN] the C Axis. The value in C AXIS ACTUAL is 0.
13
Open and close the cutoff valve to engage the actuator block. The value in C AXIS ACTUAL must stay at 0.
14
Remove the air regulator and cutoff valve from the air supply tube for the actuator.
Connect the air-supply tube to the actuator block for the C Axis.
Set Parameter 278:26 to 1.
16
Type M154; M155; M99; in MDI mode.
If the adjustment is correct, the machine orients the spindle and correctly engages the c-axis. If an alarm occurs, make sure the grid offset is correct. And examine the pulley for the spindle encoder.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
