UMC - X and Y Axes - Tool Change Offsets
Service Home How To Procedures UMC - X and Y Axes - Tool Change Offsets
Recently Updated Last updated: 03/05/2021
- Jump to Section - 1.  X and Y-Axes - Tool Change Offsets (4 steps) 2. Next Generation Control (1 step) 3. Classic Haas Control (1 step) Back to Top
Go into DEBUG mode. Push [RESET], [ZERO RETURN], then [ALL]. Put the top part of the split tool into the pocket. Put the bottom part of the split tool into the double-arm.
Use the tool changer RECOVER mode to move the arm until the value of Arm at CL/UNCL is 1.
Jog the X and Y Axes to align the top and bottom parts of the split tool. Push [.0001/.0]. Jog the Z-Axis towards the double-arm until the top and bottom parts of the split tool almost touch. Do not let the two parts touch.
Jog the X and Y Axes until the alignment pin [1] goes smoothly in and out of the split tool parts.
 Caution: Do not let the spindle hit with the double-arm. This bends the double-arm.
For Next Generation Control:
Go into Service mode.  Go to the Parameters > Factory Settings [1,2] page.
Type in .078 press [F1] [3]
Enter the axis letter and press [F2] to set the tool change offset [4].
Set the offset for both X and Y axis.
Use the tool changer RECOVER mode to move the arm until the values of Arm at Origin and Arm at Stop are 1.
Push [ZERO RETURN], then [ALL]. Remove the split tool from the double-arm and spindle. Go out of Service mode.
For Classic Haas Control: Go to the DEBUG RAW DATA page. Record the COMMAND values for the X and Y Axes.
Enter the recorded values to Parameter 210 X TOOL CHANGE OFFSET and Parameter 211 Y TOOL CHANGE OFFSET. Enter the values as negative numbers. Do not include the decimal point.
For example, set Parameter 210 to ‑19536920, and set Parameter 211 to ‑5628329.
Put a soft material on the table to protect the table if a tool holder falls.
Put a tool holder [1] into the spindle.
Close the operator door.
If your machine has a servo tool changer, push [25% RAPID].
Go into MDI mode.
Push [ATC FWD] and [ATC REV] many times.
If you have no problems at 25% do this step again at 100%.
