    3. Español
    13. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    3. Español
    13. Русский
Search
Electrical Component Corrosion Prevention Procedure
Service Home Electrical Component Corrosion Prevention Procedure
Recently Updated Last updated: 05/25/2022
- Jump to Section - 1. Introduction 2. Electrical Connection Corrosion Prevention (2 steps) 3. Solenoid Corrosion Prevention (1 step) Back to Top
Perform this procedure if the electrical connectors or solenoid assembles come into contact with coolant, or any time during a service call that you notice electrical connectors or solenoid assemblies with signs of corrosion from coolant exposure. This may happen if a coolant hose breaks in the spindle head assembly or a bearing-style TSC union fails.
Caution: Coolant contamination can cause corrosion in electrical connectors. This corrosion then causes intermittent circuit failures that are very difficult to diagnose.
Warning: Wear eye protection during this procedure.
Caution: Do not do this procedure or use WD-40(R) for components inside the control cabinet. WD-40 is a solvent/oil solution that can be used to clean solenoids, fittings, and other mechanical components. Always remember to use clean shop air to blow off excess WD-40.
Note: Do not allow excess WD-40 to remain on connectors or wires. WD-40 will leave a small amount of oil on the components, which will attract dirt.
Disconnect the male and female ends of the connector.
Inspect the connector pins. Look for blue/green stains, or a green or white powder, on the male or female pins. These are signs of corrosion.
If you find corrosion, apply WD-40 to both ends of the connector.
Allow the WD-40 to work for a few seconds to dissolve the built-up corrosion.
Use an air gun to thoroughly blow off the excess WD-40.
Apply dielectric grease (silicone grease) to one of the connector ends, then connect the cables.
Caution: Make sure to use only dielectric grease (silicone grease)
Caution: DO NOT use silicone adhesive.
If the connectors do not have corrosion, spray WD-40 into each connector shell as a preventive measure. There is no need to disassemble the connector.
Use an air gun to thoroughly blow off the excess WD-40. Do not allow excess WD-40 to remain on connectors or wires. WD-40 will leave a small amount of oil on the components, which will attract dirt. Repeat this procedure for all of the electrical connections in the spindle head area.
Inspect all of the solenoid assemblies and their connections in the spindle head area. Look for blue/green stains, or a green or white powder, on the solenoid and the connections [1]. These are signs of corrosion.
Apply WD-40 to each solenoid assembly as a preventive measure. There is no need to disassemble the solenoid assemblies. Allow the WD-40 to work for a few seconds to dissolve the built-up corrosion.
Use the air gun to thoroughly blow off the excess WD-40. Do not allow excess WD-40 to remain on connectors or wires. WD-40 will leave a small amount of oil on the components, which will attract dirt. Repeat the procedure for all of the solenoids in the spindle head area.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
