8 - BF - G-Codes
Haas Bar Feeder - Operator's Manual Supplement
  • 0 - Haas Bar Feeder - Table of Contents
  • 1 - BF - Introduction
  • 2 - BF - Legal Information
  • 3 - BF - Safety
  • 4 - BF - Installation
  • 5 - BF - Control Icons
  • 6 - BF - Operation
  • 7 - BF - Programming
  • 8 - BF - G-Codes
  • 9 - BF - Settings
  • 10 - BF - Maintenance
8.1 Bar Feeder - G-Codes
This page gives detailed descriptions of the G-codes that you use to program your Haas Bar Feeder.  For information about G-Codes used to program Haas Lathe machines see the Lathe - G-Codes tab.
CAUTION: The sample programs in this manual have been tested for accuracy, but they are for illustrative purposes only. The programs do not define tools, offsets, or materials. They do not describe workholding or other fixturing. If you choose to run a sample program on your machine, do so in Graphics mode. Always follow safe machining practices when you run an unfamiliar program.
NOTE: The sample programs in this manual represent a very conservative programming style. The samples are intended to demonstrate safe and reliable programs, and they are not necessarily the fastest or most efficient way to operate a machine. The sample programs use G-codes that you might choose not to use in more efficient programs.
What are G-Codes?
  • 8.1 BF - SPECIFIC G-CODES
  • 8.2 LATHE - G-CODES
G-Code  Description Group
G105 Servo Bar Command 09
G00 Rapid Motion Positioning 01
G01 Linear Interpolation Motion 01
G02 CW Circular Interpolation Motion 01
G03 CCW Circular Interpolation Motion 01
G04 Dwell 00
G09 Exact Stop 00
G10 Set Offsets 00
G12 Circular Pocket Milling CW
G13 Circular Pocket Milling CCW
G14 Secondary Spindle Swap 17
G15 Secondary Spindle Swap Cancel 17
G17 XY Plane 02
G18 XZ Plane 02
G19 YZ Plane 02
G20 Select Inches 06
G21 Select Metric 06
G28 Return To Machine Zero Point 00
G29 Return From Reference Point 00
G31 Skip Function 00
G32 Thread Cutting 01
G40 Tool Nose Compensation Cancel 07
G41 Tool Nose Compensation (TNC) Left 07
G42 Tool Nose Compensation (TNC) Right 07
G43 Tool Length Compensation + (Add) 08
G47 Text Engraving 00
G50 Spindle Speed Limit 00
G51 Set Global coordinate Offset FANUC 00
G52 Set Local Coordinate System FANUC 00
G53 Machine Coordinate Selection 00
G54 Coordinate System #1 FANUC 12
G55 Coordinate System #2 FANUC 12
G56 Coordinate System #3 FANUC 12
G57 Coordinate System #4 FANUC 12
G58 Coordinate System #5 FANUC 12
G59 Coordinate System #6 FANUC 12
G61 Exact Stop Modal 15
G64 Exact Stop Cancel G61 15
G65 Macro Subprogram Call Option 00
G68 Rotation 16
G69 Cancel G68 Rotation 16
G70 Finishing Cycle 00
G71 O.D./I.D. Stock Removal Cycle 00
G72 End Face Stock Removal Cycle 00
G73 Irregular Path Stock Removal Cycle 00
G74 End Face Grooving Cycle 00
G75 O.D./I.D. Grooving Cycle 00
G76 Threading Cycle, Multiple Pass 00
G80 Canned Cycle Cancel 09
G81 Drill Canned Cycle 09
G82 Spot Drill Canned Cycle 09
G83 Normal Peck Drilling Canned Cycle 09
G84 Tapping Canned Cycle 09
G85 Boring Canned Cycle 09
G86 Bore and Stop Canned Cycle 09
G89 Bore and Dwell Canned Cycle 09
G90 O.D./I.D. Turning Cycle 01
G92 Threading Cycle 01
G94 End Facing Cycle 01
G95 Live Tooling Rigid Tap (Face) 09
G96 Constant Surface Speed On 13
G97 Constant Surface Speed Off 13
G98 Feed Per Minute 10
G99 Feed Per Revolution 10
G100 Disable Mirror Image 00
G101 Enable Mirror Image 00
G103 Limit Block Lookahead 00
G107 G107 Cylindrical Mapping 00
G110 Coordinate System #7 12
G111 Coordinate System #8 12
G112 XY to XC Interpolation 04
G113 Cancel G112 04
G114 Coordinate System #9 12
G115 Coordinate System #10 12
G116 Coordinate System #11 12
G117 Coordinate System #12 12
G118 Coordinate System #13 12
G119 Coordinate System #14 12
G120 Coordinate System #15 12
G121 Coordinate System #16 12
G122 Coordinate System #17 12
G123 Coordinate System #18 12
G124 Coordinate System #19 12
G125 Coordinate System #20 12
G126 Coordinate System #21 12
G127 Coordinate System #22 12
G128 Coordinate System #23 12
G129 Coordinate System #24 12
G154 Select Work Coordinates P1-99 12
G156 Broaching Canned Cycle 09
G167 Modify Setting 00
G170 G170 Cancel G171/G172 20
G171 G171 Radius Programming Override 20
G172 G172 Diameter Programming Override 20
G184 Reverse Tapping Canned Cycle For Left Hand Threads 09
G186 Reverse Live Tool Rigid Tap (For Left Hand Threads) 09
G187 Accuracy Control 00
G195 Forward Live Tool Radial Tapping (Diameter) 09
G196 Reverse Live Tool Radial Tapping (Diameter) 09
G198 Disengage Synchronous Spindle Control 00
G199 Engage Synchronous Spindle Control 00
G200 Index on the Fly 00
G211 Manual Tool Setting -
G212 Auto Tool Setting -
G234 Tool Center Point Control (TCPC) 08
G241 Radial Drill Canned Cycle 09
G242 Radial Spot Drill Canned Cycle 09
G243 Radial Normal Peck Drilling Canned Cycle 09
G245 Radial Boring Canned Cycle 09
G246 Radial Bore and Stop Canned Cycle 09
G249 Radial Bore and Dwell Canned Cycle 09
G250 Cancel Scaling 11
G251 Scaling 11
G254 Dynamic Work Offset (DWO) 23
G255 Cancel Dynamic Work Offset (DWO) 23
G266 Visible Axes Linear Rapid %Motion 00
G268 Enable Feature Coordinate System 02
G269 Disable Feature Coordinate System 02
G390 Absolute Position Command 03
G391 Incremental Position Command 03
