  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Axis-Lubrication Reservoir Assembly - Replacement - AD0358
Service Home How To Procedures Axis-Lubrication Reservoir Assembly - Replacement - AD0358
Recently Updated Last updated: 12/04/2020
Axis-Lubrication Reservoir Assembly- Replacement
AD0358
- Jump to Section - 1. Axis-Lubrication Reservoir Assembly- Replacement (3 steps) 2. Grease Reservoir - Prime and Test (2 steps) Back to Top
Label the output grease hoses from the used axis-lubrication reservoir assembly so they can be put back in the same location when you are finished replacing the assembly.
Disconnect the input air hose and output grease hoses from the used axis-lubrication reservoir.
Remove the used axis-lubrication reservoir assembly from the cabinet.
Disconnect the pressure switch cable from the assembly.
Remove the air input fitting and the grease manifold fro the used axis-lubrication reservoir assembly.
Remove and discard the used 1/4" OD tube (same location as a new hose [2] shown in image) from the grease manifold [1].
Install the air input fitting [5] into the new axis-lubrication reservoir assembly [3]. Orient the top of the air input fitting parallel to the two screw bosses [4] on the new axis-lubrication reservoir [3].
Look at the bottom tip of the hose [5]. Verify:
  • The tip must be cut at 45 degrees.
  • It must clear the filter screen by approximately 1/16" (2mm).
  • If it is necessary to shorten the hose, cut it at the top.
    • Leave enough hose to make a god connection with the grease manifold [1].
    • Do not kink the hose.
Do not pull the new tube completely out of the port on the head. only pull the new 1/4" OD tube [2] one or two inches from the port on the head of the new axis-lubrication reservoir assembly that has the "OUT" label. Insert the tube until it is firmly seated in the fitting in the grease manifold [1].
Install the grease manifold [1] into the new axis-lubrication reservoir assembly[3]. The holes on top of the air input fitting [4] and grease manifold [1] must be aligned as shown [6].
Install the metal reservoir with grease [6]. Install the completed new axis-lubrication reservoir assembly into the cabinet.
Use the adapter bracket [1] if the holes in the cabinet do not match the holes in the head assembly. Make sure the bracket is oriented as shown.
Note: Damage can occur over time if the vertical axis hose is not connected to an output with a check valve. Air can get into the hose and the vertical axis won't get adequate lubrication.
Connect the input air hose [5] and output grease hoses. Make sure to install the vertical axis to the output port with the check valve [3]. The other axes are installed on the hose fittings [4].
Connect the pressure switch cable to the pressure switch behind the grease manifold [2].
If the machine has a Classic Haas Control, do these steps:
  • Press [PARAMETER DIAGNOSTIC] (2) times to show the diagnostics page.
  • Press [CANCEL].
  • Go to the [LUBE] tab.
  • Press [WRITE/ENTER] .
  • Press [F2] to start the Axis-Lubrication Test.
If the machine has as Next Generation Control, do these steps:
  • Press [DIAGNOSTICS].
  • Go to the [MAINTENANCE] tab.
Perform the Axis-Lubrication Test again until you no longer get axis lubrication alarms. Wait a minimum of (1) minute between Axis-Lubrication Test cycles.
Check the level of the grease in the reservoir.
If the grease lines were nearly empty, it may be necessary to refill the axis-lubrication reservoir after you purge the lines of air. Pour the grease into the reservoir: to about 1/2" (13mm) below the threads on the reservoir.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
