40-Taper - Belt-Drive - TSC-Ready - TSC - 300 and 1K PSI - Installation - VMC - NGC - AD0292
Service Home How To Procedures 40-Taper - Belt-Drive - TSC-Ready - TSC - 300 and 1K PSI - Installation - VMC - NGC - AD0292
Recently Updated Last updated: 04/28/2025
AD0292
Applies to machines built from: January, 2016
- Jump to Section - 1. Introduction 2. Install Kit 3. Tools Required 4. 40-Taper - Belt-Drive - TSC-Ready - TSC - 300 and 1K PSI - Installation (10 steps) 5. TSC 1K PSI - Motor Drive PCB and Electrical Components - Installation (5 steps) 6. TSC - 300 and 1K PSI - Pump - Installation (3 steps) 7. TSC - 300 and 1K PSI - Test (2 steps) Back to Top
  1. TSC Coolant Pump
  2. TSC Check-Valve Assembly
  3. Vacuum Generator
Install Kit
To select the correct TSC install kit for your machine refer to: Through Spindle Coolant - Field Install Kits
Tools Required
  • Spindle Lock Tool (T-1635)
  • Red-I Grease
  • Dial Indicator (that can measure 0.0001") with Magnetic Base
Push [POWER OFF].
Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
 Danger: If the vector drive voltage indicator light is on, do not touch the electrical components. The high voltage in the control cabinet can kill you. Wait for the voltage indicator LED on the vector drive to go off completely.
Close the primary air valve. Pull the ring on the bleed valve in the air manifold. Wait until all air pressure is released.
Look at the manifold pressure gauge. Make sure that the air pressure is 0 psi.
Remove the spindle head covers.
Install the spindle lock tool (T-1635) onto the spindle.
Put these parts through the cable channels:
  • 20' (6096 mm) 1/4" gray tube [1]
  • 20' (6096 mm) 1/4" purple tube [2]
  • 3/8" hose [A]
Connect the 19" (483 mm) cable [B] to the TSC PRESSURE connector [3] on the electrical bracket.
Disconnect the 5' (1524 mm) 1/4" black tube [1] from the push-lock fitting [2]. The push-lock fitting [2] is on the top of the TRP-spring retainer [3].
Remove and discard the push-lock fitting [2] from the TRP 90-degree fitting [4].
 Caution: While you turn the push-lock fitting, make sure you support the fitting [4] to make sure the fitting [4] does not turn. The fitting [4] could break if it turns.
Remove these parts from the TRP:
  • 1/4" black tube [2]
  • 1/4" black-tube fitting [1]
  • 1/8" fitting [3]
Discard the fitting [1] and the tube [2].
Install these parts to the TRP fitting:
  • 1/8" hex fitting [4]
  • 1/8' check valve [5] (make sure the arrow is in the direction shown).
  • 1/8" fitting [6]. This is the fitting that you removed from the TRP.
Attach the TSC check-valve assembly [9] to the bracket [10]. Use the (2) 1/4-20 x 1-1/2" socket-head cap screws (SHCS) [8].
Install the assembly [9] to the rear head-cover of the machine. Use the (2) 1/4-20 x 1/2" flanged button-head cap screws (FBHCS) [7].
Connect these components to the TSC check-valve assembly:
  • 3/8" hose [A]
  • 19" (483 mm) cable [B]
  • 5' (1524 mm) 1/4" black tube [1]
  • 20' (6096) 1/4" purple tube [2]
  • high-pressure braided hose [3]
Connect the braided hose [3] to the TRP 90-degree fitting [4].
Connect the other end [5] of the tube [1] to the TRP fitting assembly [6].
Connect the 3/8" hose [8] to the coolant-drain port [7].
 Note: The next (3) steps will show you how to install the vacuum generator. Choose the correct configuration.
If you have the dome plugs [1] near the front of the spindle:
Remove the plugs [1].
Connect these parts to the vacuum generator [5]:
  • 5' (1524 mm) 1/4" gray tube [2]
  • Use the clamp [3] to connect the 3/8" black hose [4].
Find the space towards the front of the spindle. Move the vacuum generator [5] down into the space.
Install the vacuum generator [5]. Use a 1/4-20 x 1/2" flanged button-head cap screw (FBHCS) [6].
If the dome plugs [1] are near the rear of the spindle:
Remove the plugs [1] and the bottom spindle-head cover [2].
Install the vacuum generator [4] on the cover [2]. Use a 1/4-20 x 1/2" FBHCS.
Put theses through the opening behind the spindle:
  • 3/8" black hose [6]
  • 5' (1524 mm) 1/4" gray tube [3]
Connect these parts to the vacuum generator:
  • Use the clamp [5] to connect the hose [6].
Install the cover [2].
For machines that have a large opening [5] on the left side of spindle head casting:
Connect these parts to the vacuum generator [2]:
  • 5' (1524 mm) 1/4" gray tube [1]
Install the vacuum generator [2] in the large opening [5]. Use a 1/4-20 x 1/2" FBHCS [6].
Open the door to the lubrication cabinet.
From the bottom of the manifold, remove and discard the third manifold plug [1].
 Note: Clean the manifold port threads.
Install the compression fitting [2] on the TSC-purge solenoid [3]. This solenoid [3] has (2) purple cable ties. Install the solenoid [3] in the third manifold port from the bottom.
Remove the plug [5] for the pre-charge solenoid [6].
Install the elbow fitting [4] that has the gray cable tie to the pre-charge solenoid [6].
Cut the 20' (6096 mm) 1/4" purple tube [7] to the correct length. Connect the tube [7] to the check valve fitting [11] of the solenoid [3].
Connect the 20' (6096 mm) 1/4" gray tube [8] to the solenoid [6].
Connect the TSC-purge solenoid cable [10] to the TSC UNION section [9] on the connector panel.
Remove the cover [1] for the power supply (PSUP) PCB.
Remove the push-on covers [2] for the connectors from position CB4.
Remove the electrical jumper at position JP2 [3] on the PSUP PCB.
Install the 15A circuit breaker [4] at position CB4.
 Caution: When you handle a PCB, you must wear an Electrostatic Discharge (ESD) strap.
For TSC 1K machines and if you do not have a door panel installed in the control cabinet:
Open the control cabinet. Remove the cover for the I/O PCB.
Install these parts:
  • Use (2) screws [2] to install the top hinge plate [1].
  • Use (2) screws [3] to install the bottom hinge plate [4].
  • Use (4) screws [5] to install the (2) door brackets [6].
  • door panel [7]
Install these parts on the door panel:
  • (2) spacers [1]
  • motor-drive PCB [G]
  • (2) socket-head cap screws (SHCS) [2]
Connect the 33-1974 cable [H] to these locations:
  • P2 [3] on the motor-drive PCB (put the cable [H] through the left cable-carrier channel).
  • P10 [4] on the I/O PCB.
Connect the 33-0987B cable [I] to these locations:
  • P4 [1] on the motor-drive PCB (put the cable [I] through the top and right cable channels).
  • Connections 77, 78, and 79 [2] on the transformer (each wire has an identification label).
Connect the 12' TSC extension cable [C] to P1 [3] on the motor-drive PCB.
Put the cable [C] through the top and right cable channels.
For TSC 1K machines:
Put the cable [C] behind the cover of the receptacle bracket.
Remove the AUX COOLANT plug [3] from the receptacle bracket.
Install the clamp [2] around the receptacle end [1] of the cable [C].
Use the (2) screws to attach the clamp [2] to the receptacle bracket.
Install the bracket [2] for the fan assembly. Use the (2) 1 x 1/4" Phillips pan-head screws (PPHS) [1]. Make sure the arrows [3] on the fan assembly point in the correct direction.
Install the fan assembly [4] to HS6 [3] on the I/O PCB. Use the (2) 1/4" PPHS [5].
Connect the fan-assembly cable [7] to P11 [6] on the I/O PCB.
  • Remove and discard the larger cover adjacent to the standard coolant pump.
  • Install the smaller cover adjacent to the standard coolant pump.
  • Install the TSC pump [E]. If necessary, remove the #8 fitting [1] and install the #6 fitting [2]. The #6 fitting [2] is for machines that have a 3/8" hose.
On the TSC-purge solenoid, find the fitting [4] that does not have a check valve. Connect the other 20' (6096 mm) 1/4" purple tube [3] to the fitting [4] and to the air cylinder on the pump.
Connect the 3/8" hose [A] to the pump.
If you did not install the 12' TSC extension cable [C]:
Discard the plug [5] for the receptacle bracket.
Install the 12' TSC extension cable [C].
Connect the 4-pin connector [1] of the cable [C] to P31 [2] on the I/O PCB.
Install the receptacle end [3] of the cable [C] to the receptacle bracket. Use the twist lock mount [4] and the screws.
Connect the power cable for the TSC coolant pump to the receptacle end [3] of the TSC extension cable [C].
Install the 13.5' vacuum-sensor cable [D] between P28 [1] on the I/O PCB and to the vacuum sensor [2] for the TSC pump.
Refer to the Next Generation Control - Option Activation procedure.
Operate this code in MDI:
M59 P26 ;
G04 P5.0 ;
M69 P26 ;
G04 P2.0 ;
M99 ;
P26 is for inline spindles.
For belt-drive spindles, use P35 and not P26.
The bearingless TSC union moves up and down at 7-second intervals. The up and down movement is small.
The illustration shows the up and down movements for 40-taper [1], 40-taper (CALM) [2], and 50-taper [3] machines.
Put a TSC toolholder [1] in the spindle. Push [AUX CLNT] to start the TSC.
Correct operation is as follows:
  1. Coolant flows correctly from the TSC tool holder.
  2. A few drops flow from the vacuum-generator hose [2].
Push [RESET].
