    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Fixture Clamps
      • Toolmakers Vise
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Test Bars
      • Tool Setting Measuring Gauges
      • Plug & Ring Gauges
      • Gauge Blocks & Accessories
      • Pin Gauges & Accessories
    • Deals Of The Week
      Deals Of The Week Shop All
      • Grooving Tools
      • Cut-Off Tooling
      • Boring Bars
      • OD Toolholders
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
40-Taper - Spindle Drawbar - Go-No-Go Check and Adjustment - AD0310
Service Home How To Procedures 40-Taper - Spindle Drawbar - Go-No-Go Check and Adjustment - AD0310
Recently Updated Last updated: 01/17/2019
AD0310
Applies to machines built from: January, 1989
- Jump to Section - 1. Introduction 2. Tools Required 3. Parts Required 4. 40-Taper - Spindle Drawbar - Go-No-Go Check and Adjustment (5 steps) Back to Top
  1. Use the Go-No-Go gauge [1] to make sure that the drawbar releases a tool from a 40-taper spindle before the tool unclamp (disengage) switch is energized. If you cannot see the o-ring [2] on the gauge, adjustment is not necessary. If you can see the o-ring [3], adjustment is necessary.
  2. Make adjustments if necessary.
Tools Required
KIT PN: 93-2582, 40T Drawbar-Validation Tool . QTY: 1
Parts Required
  • AIR REGULATOR 5 - 100PSI 1/8NPT (P/N 58-2740) QTY: 1
  • FITG NPT1/8M NPT1/4F 90 BRASS (P/N 58-3614) QTY: 2
  • FITG POLY1/2M NPT1/4F STR BRASS (P/N 58-1574) QTY: 3
  • GAUGE 0-160 PSI X NPT-1/8-M BACK (P/N 58-27395) QTY: 1
  • FITG PC1/2F NPT1/4M STR STL (P/N 58-0231) QTY: 4
  • FITG (P/N 58-2065) QTY: 1
  • HOSE 1/2 OD PE CLEAR (P/N 58-2022) QTY: 30'
Make an air-regulator tool with a pressure gauge attached. Assemble these parts from the "Tools Required" section:
  • Pressure Gauge (P/N 58-27395) [1]
  • Air Regulator (P/N 58-2740) [2]
  • 90-degree fittings (P/N 58-3614) [3]
  • fittings (P/N 58-1574). Some machines use this type of fitting, as shown in the illustration [4].
  • fittings (P/N 58-0231). Other machines use this type of fitting, not shown in the illustration [4].
  • 30' of hose (P/N 58-2022) [5]
  • Measure the necessary lengths and cut the hose into two sections. Make sure the sections have the length to let you look at the control display while you adjust the air-regulator tool.
Install one tube section [1] from the TRP solenoid to the input of the air-regulator tool.
 Note: For CALM machines, the TRP solenoid is in the air-lubrication cabinet. For pre-CALM machines, the TRP solenoid is near the spindle head.
Install the other tube section [2] from the output of the air-regulator tool to the TRP air supply.
Adjust the air-regulator tool to 70 psi (4.8 bar). Monitor Drawbar Open on the [DIAGNOSTICS] display while you push and hold [TOOL RELEASE] for 5 seconds. Decrease the pressure of the air-regulator tool in increments of 1 psi until Drawbar Open does not change to 1 when you push and hold the tool-release button.
Hold the tool-release button while you put the go-no-go gauge into the spindle. If the red o-ring goes into the spindle taper [1], no adjustment is necessary. If the red o-ring does not go into the spindle taper [2], adjustment is necessary.
 Note: If the red o-ring does not go into the spindle taper, this tells you that the tool cannot go into the spindle before the switch changes state (before Drawbar Open changes to 1). Thus you must make adjustments, as shown in the next steps.
If the red o-ring did not go into the spindle taper, refer to one of these procedures to make the necessary adjustment:
If the TRP switch is adjustable [1], refer to:
  • VMC - TRP Sensor - Adjustment
If the TRP switch is not adjustable [2], refer to the Add or Remove Shims section of the above procedure.
 Note: If the TRP switch is not adjustable, the necessary number of shims can be higher than normal for this procedure.
Again hold the tool-release button while you put the go-no-go gauge into the spindle. Make sure the red o-ring goes into the spindle taper.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
