  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Bar Feeder
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Threading Toolholders
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
50-Taper - Belt-Drive - TSC Ready - Bearingless TSC Union - Replacement - VMC - AD0069
Service How To Procedures 50-Taper - Belt-Drive - TSC Ready - Bearingless TSC Union - Replacement - VMC - AD0069
Recently Updated Last updated: 01/17/2019
AD0069
Applies to machines built from: January, 2013
- Jump to Section - 1. Introduction 2. Parts Required 3. Tools Required 4. 50-Taper - Belt-Drive - TSC Ready - Bearingless TSC Union - Replacement - VMC (6 steps) 5. CHC - TSC - 300 and 1K PSA - Test (2 steps) 6. NGC - TSC - 300 and 1K PSI - Test (2 steps) Back to Top
Bearingless TSC Union [1]
Factory installed bearingless TSC unions for both 300, 1000, and 1K psi systems are assembled with 85 psi regulators. The internal piston seal on these unions is configured differently. The 300 psi system has the force of a 35 psi regulator and the 1000/1K psi system has the force of an 85 psi regulator. The replacement union ships with a 35 psi regulator. It can be configured to supply the 85 PSI needed for the 1000/1K psi systems as shown in this procedure.
Perform this procedure for these TSC configurations:
  • TSC 300 psi
  • TSC 1000 psi (This configuration has the coolant-pump cart.)
  • TSC 1K psi
 Note: The images in this document show TSC 1000 and 1K psi.
Parts Required
93-2129 QTY: 1
COOLANT UNION, BEARINGLESS ASSEMBLY 50 TAPER 300/1000 PSI
Tools Required
  • Spindle Lock Tool (T-2080)
  • Red-I Grease
  • Dial Indicator (that can measure 0.0001") with Magnetic Base
Push [POWER OFF].
Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
 Danger: If the vector drive voltage indicator light is on, do not touch the electrical components. The high voltage in the control cabinet can kill you. Wait for the voltage indicator LED on the vector drive to go off completely.
Close the primary air valve. Pull the ring on the bleed valve in the air manifold. Wait until all air pressure is released.
Look at the manifold pressure gauge. Make sure that the air pressure is 0 psi.
Remove the spindle head covers.
Install the spindle lock tool (T-2080) onto the spindle.
Remove and record the location of these parts from the bearingless TSC union [6]:
  • high-pressure braided hose [1]
  • 20' (6096 mm) 1/4" gray tube [2]
  • 5' (1524 mm) 1/4" gray tube [3]
  • clamp for the 3/8" black hose [4]
  • 3/8" black hose [5]
Remove these parts from the TSC adapter:
  • (4) 10-32 x 3/4" socket-head cap screws (SHCS) [7]
  • bearingless TSC union [6]
Use a 1" deep socket [1] to loosen the extension tube assembly. Turn the assembly clockwise to loosen it.
Remove the extension tube assembly [2]. Turn the assembly clockwise to loosen it.
Remove the shaft [3] for the extension tube assembly. Turn the shaft clockwise to loosen it.
Perform this step only for TSC 1000 or 1K psi to bypass the 35 psi regulator.
Find the replacement bearingless TSC union [A].
Remove the regulator plug [1] from the regulator port.
Remove the fitting assembly [2] from the regulator port with an arrow.
 Note: The mark on the regulator port can be different than this illustration.
Install the plug [1] into the regulator port with an arrow.
Install the fitting assembly [2] into the open regulator port.
To install the extension tube assembly [2]:
  • Apply Red-I grease to the o-ring of the shaft [1] and to the assembly [2].
  • Assemble the shaft [1] to the extension tube assembly [2].
  • Put the assembly [2] through the TSC adapter.
 Note: Make sure the spring is in the adapter.
  • Turn the assembly [2] counterclockwise to tighten it. Use the 1" (25 mm) deep socket [3].
  • Torque the assembly [2] to 35 ft-lb (47.4 Nm).
  • Remove the spindle lock tool.
  • Use the dial indicator to measure the total indicated runout (TIR) of the shaft [2].
 Note: The TIR must be less than 0.001" (0.025 mm). If the TIR is more than 0.001" (0.025mm), contact Haas service.
Use a stone on the surface of the TSC adapter.
Install these parts on the TSC adapter:
  • replacement bearingless TSC union [1]
  • (4) 10-32 x 3/4" socket-head cap screws (SHCS) [2]
Install these parts on the repalcement bearingless TSC union [1]:
  • high-pressure braided hose [3]
  • 20' (6096 mm) 1/4" gray tube [4]
  • 5' (1524 mm) 1/4" gray tube [5]
  • clamp for the 3/8" black hose [6]
  • 3/8" black hose [7]
Operate this code in MDI mode:
M59 P1148 ;
G04 P5.0 ;
M69 P1148 ;
G04 P2.0 ;
M99 ;
P1148 is for inline spindles.
For HS machines, use P1124 and not P1148.
For belt-drive spindles, use P1120 and not P1148.
If the machine has a bearingless TSC union, it moves up and down at 7-second intervals. The up and down movement is small.
The illustration shows the up and down movements for 40-taper [1], 40-taper (CALM) [2], and 50-taper [3] machines.
Put a TSC toolholder [1] in the spindle. Push [AUX CLNT] to start the TSC.
Correct operation is as follows:
  1. Coolant flows correctly from the TSC tool holder.
  2. A few drops flow from the vacuum-generator hose [2].
Push [RESET].
Operate this code in MDI:
M59 P26 ;
G04 P5.0 ;
M69 P26 ;
G04 P2.0 ;
M99 ;
P26 is for inline spindles.
For belt-drive spindles, use P35 and not P26.
The bearingless TSC union moves up and down at 7-second intervals. The up and down movement is small.
Push [RESET].
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
