Pallet Changer - Troubleshooting Guide - NGC - TG0108
Service Home Pallet Changer - Troubleshooting Guide - NGC - TG0108
Recently Updated Last updated: 10/14/2025
TG0108
- Jump to Cause - 1. Introduction 2. Symptoms 3. Clamp/Unclamp I/O Status 4. H-Frame Up/Down I/O Status 5. H-Frame Rotate CW/CCW I/O Status 6. Electrical Diagrams 7. EC-400 APC Gear Rack Version Change (2 steps) 8. Air Blast Manifold Seal (1 step) Back to Top
Use this troubleshooting guide to find and correct problems with the Hydraulic Pallet Changer.
For related inspection reports follow the link below. Be sure to download the correct inspection report for the correct machine. EA0419 for EC-400/500 and EA0429 for EC-500/50 and EC-630.
Inspection Report List
Pallet Change Sequence
  1. Check that pallet is clamped to the receiver.
  2. Move the Z-axis and B-axis to zero position.
  3. Unclamp the pallet.
  4. Using hydraulic pressure the H-frame is lifted, rotated and lowered.
    Note: The air blast is on while the pallet is rotating. Air pressure is monitored by the air pressure system.
  5. The pallet is clamped to the receiver.
When a pallet change occurs, a request for hydraulic demand is sent to the HPU.  The HPU will monitor hydraulic pressure during the pallet change.  The pallet change is not permitted to advance if hydraulic pressure is insufficient. If the pressure is absent for a parameterized time period, an alarm is generated.
Settings:
  • 216 Servo and Hydraulic Shutoff
  • 382 Disable Pallet Changer
Pallet Changer - Bottom View
  1. Full CCW sensor
  2. Full CW sensor
  3. H-Frame (Pallet) Up Sensor
  4. H-Frame (Pallet) Down Sensor
  5. Rack
  6. Hydraulic Cylinder (CW/CCW)
  7. H-Frame Lift Cylinder
  8. Lock Station Handle
  9. Rack Stop Adjustment Screw
Fourth Axis Receiver - Side View
  1. 4th Axis Receiver
  2. 4th Axis Home Sensor
  3. Hydraulic Clamp/Unclamp Input
  4. Air Blast Input
  5. Pallet Unclamp Sensor
  6. Pallet Clamp Sensor
Symptoms
Alarm 644 APC Low Air Pressure The air pressure is low during a pallet change. Check for air leaks and air pressure on the lube cabinet.
Alarm 945 APC Pallet Lower Timeout The H-frame down sensor was not contacted before the timeout period. Check the H-Frame down sensor to make sure it changes states.
Alarm 956 APC Lift Frame Up Timeout The H-frame up sensor was not contacted before the timeout period. Check the H-Frame up sensor to make sure it changes states.
Alarm 9114 H-Frame Rotate Timeout The CW/CCW solenoids are not actuating. Check that the CW/CCW solenoids are getting 115 VAC from the I/O PCB.
Alarm 9115 APC Illegal Switch Condition Rotate Frame The H-Frame CW/CCW inputs are in a invalid state during a Pallet Change. Make sure the H-frame CW/CCW inputs are changing to the correct states.  Look at the H-Frame CW/CCW I/O status section below.
Alarm 9116 APC Pallet is Unclamped The pallet clamp/unclamp inputs are in a invalid state.
Make sure the pallet clamp/unclamp inputs are changing to the correct states.  Look at the Clamp/Unclamp I/O section below.
Pallet lowers before reaching clamp position. Switch position is not correct.  Adjust the switch/bracket. If there is not enough adjustment, the gear rack was changed to have a notch added so it would not trip the sensor before the pallet was in place. The switch mount block was also changed to a shorter length. Replace the gear rack and switch mount block with the new version. Check to see what version you have before ordering replacement part.
Pallet cylinder damper is not slowing the pallet, causing it to slam into the hard stop. Damper adjustment or switch adjustment is not correct. Adjust the damper on the cylinder. Counter clockwise on the screw to open and speed up the damper. Clockwise to close and slow it down. It may be closed or clogged and needs to be open more to clear it out.
Recovery Required Message keeps appearing on the screen after a pallet change. The H-Frame (Pallet Changer) at Full CW/CCW sensor are loose. Make sure the H-Frame (Pallet Changer) at Full CW/CCW sensors are working and they are correctly fasten.  See H Frame Rotate CW/CCW I/O Status section below.
Minimal air coming out of air blast manifold  Debris entering the air blast assembly New version of air blast manifold (20-7437A) has a shaft seal (57-0813) to prevent debris from entering the assembly. See Air Blast Manifold Seal Section for further detail.
Pallet Changer Clamp/Unclamp mechanism operates in reverse. The hydrualic lines are reversed. Check at both ends of the hydrualic lift cylinder and hydraulic power unit and verify that they are set correctly.
The pallet clamp/unclamp sensors are reversed. With a Pallet on the receiver.  Command the pallet to clamp and unclamp.  Go to I/O tab and verify that inputs 25 PALLET CHANGER PALLET UNCLMPED and 29 PALLET CHANGER PALLET CLAMPED toggle to the correct state.  Check the terminal block, check that they are connected correctly.
Hydraulic fluid is leaking through the air blast. A seal is damaged or installed incorrectly.
If the EC-400/VC-400/EC-500 has been built before 3/01/2022 the machine may have been built with an old style pallet receiver assembly. Haas recommends to upgrade to the new style pallet receiver, please refer to the part numbers below. Use the Pallet Receiver & Clamp Assembly EC-400/500 - Installation procedure to install these kits.
  • 93-3465 PALLET RECEIVER & CLAMP ASSY EC-400/500
  • 93-3464 PALLET RECEIVER & CLAMP ASSY VC-400
Hydraulic fliud has leaked into the clamp/unclamp solenoid.
Hydraulic fluid is leaking between the shaft and cylinder cap.
If the machine was built after 3/01/2022 the machine may have a new style receiver. Review the Pallet Receiver & Clamp Assembly EC-400/500 - Installation document as a reference to verify which seal may have broken. There are section views that detail which seals are installed during this procedure.
Machine State
Pallet UnClamp
Input #25
Pallet Clamp
Input #29
Pallet Clamp
Output # 44
Pallet is on the workstation and clamped 0 1 0
Pallet is on the workstation and unclamped 1 0 1
No pallet on the work station and clamped 0 0 0
Machine State
H-Frame (Pallet Changer) DOWN
Input #23
H-Frame (Pallet Changer) UP
Input #35
Output # 48
Output# 165
Pallet is on the workstation and the H-frame is DOWN 1 0 0 1
Pallet is on the workstation and the H-frame is UP 0 1 1 0
Machine State
H-Frame (Pallet Changer) at Full CCW
Input #163
Input #164
H-Frame (Pallet Changer) Rotate CCW
Output # 163
H-Frame (Pallet Changer) Rotate CW
Output# 164
H-Frame at CW 0 1 0 0
H-Frame at CCW 1 0 0 0
H-Frame Rotating to CW 0 0 0 1
H-Frame Rotating to CCW 0 0 1 0
Electrical Diagrams
Pallet Changer Input Status / Solenoid Output Cable Diagrams
Auxiliary Front Panel Cable Diagram
The gear rack was changed to have a notch added so it would not trip the sensor before the pallet was in place. Replace the gear rack with the new version[2]. Check to see what version you have before ordering replacement part.
Please refer to the EC-400 - APC Rotation Cylinder - Replacement procedure for further instruction on how to remove this
The mounting block in the image to the right was made shorter to reduce the margin for sensing when the APC is fully rotated, preventing the H-frame from lowering prematurely.
The new version of the air blast manifold incldues a groove for a shaft seal 57-0813 S SEAL 3.25 X 3.614 X .211 SL WIPER. This seal can be shown in the image denoted as [1].
