BMT45 - Cluster gear Replacement - AD0776
Service Home How To Procedures BMT45 - Cluster gear Replacement - AD0776
- Jump to Section - 1. Introduction (23 steps) 2. Replacement (23 steps) 3. Reset Turret Tool Changer Alignment (2 steps) Back to Top
Recently Updated Last updated: 10/23/2024
BMT45 - Cluster Gear Replacement
AD0776
This procedure shows how to replace a cluster gear in BMT45/BOT10/VDI turret gearboxes.
This Document Applies to the following Service Kits:
  • 93-2754 GEAR, CLUSTER LATHE TURRET TOOL CHANGER
Required tools and parts :
  • T-0178 BMT45 MAIN SHAFT LOCK NUT TOOL
  • T-0159 BMT45 LT POCKET ALIGNMENT TOOL
  • T-0147 BMT45 LT OUTPUT SHAFT ALIGNMENT TOOL
  • Dial indicator
  • Service USB Key
  • 99-1686 MobilGrease XHP 222
  • 93-2365 SYNTHETIC GEAR/BEARING OIL 1QT/0.94L
  • 57-0888 GASKET TURRET REAR COVER BMT-45
Optional Parts :
  • 49-4115 WASHER 1 1/2 SS .075THKX2.062ODX1.510ID
  • 45-2001 WASHER 1 1/2 STEEL .002THK X 2 1/8
  • 51-0062 BEARING LOCKNUT BH-16
  • 57-0029 S SEAL 3.000 X 3.500 X 0.375 S1S
Machine Compatibility :
  •     ST-10/10Y/15/15Y after 04/26/2022
Note : It is recommended to use the Haas Fastener Torque Specifications
Replacement
Remove LT motor [2] by undoing motor hardware [1] then remove the motor adapter plate [4].
Remove torque arm [2] by removing the clamping bolt [1] and installing a 3/8-16 bolt into the jack screw hole above then pulling it straight back.
Remove key [3] from shaft using pliers then proceed to remove the snap ring [4] and torque arm springs.
Important : when removing the lower alignment dowel block [5] make sure to loosen the set screws [3] before removing the bolts [4].
Remove the torque arm alignment dowel blocks [2] and [5].
Important : Loosen the clamping screws on the coupler [4] before removing the motor.
Remove the TT-axis motor [2] and make sure to also remove the key [3].
Note : To save time during assembly the coupler [4] and motor [2] can be remove together by loosening the clamping screw on the opposite side of the coupler. This will also maintain the distance from the motor so reinstallation can be easier.
Remove the coupler [1] from the worm gear shaft by loosening the clamping screw and sliding it off then remove the motor mount [3] to be a able to remove the worm gear.
Remove the clamp and home proximity switches [2].
Note : If the home switch has any spacer / washers under it they need to be re-installed during assembly.
Important : The BMT45 gearbox contains 1 quart of lubricant and we recommend to prepare the work area by having plastic bags taped under the rear cover or a bucket to contain the spillage so it can be disposed of appropriately.
Remove the Rear cover [1]. If removing the cover is difficult after all the hardware [2] is removed then set screws may be inserted into the set jacking holes [3] to pop the cover. Rotating the worm gear may also help with the cover removal.
Note : Make sure to remove and inspect the wave spring [4].
Note : Replace gasket!!!  If the cover gasket is damaged during disassembly we recommend replacing it. Use a plastic scrapper to remove the old gasket material then install a new gasket P/N 57-0888.
Remove the Worm gear [1] by rotating it off the cluster gear. After removal of the cover inspect the cluster gear spring [2] and prepare for re-installation by cleaning the old grease.
Use T-0178 [2] to remove the lock nut [1].
Once the locknut [2] is removed the bearing [3] can be slid off the shaft to provide access to the cluster gear.
Remove the cluster gear [3] and retrieve the thin spacer [1] and thick spacer [2] underneath it.
Grease all the highlighted surfaces using 99-1686 MobilGrease XHP 222 then re-assemble the dowel [1] into the cluster gear [3] with the thick spacer [4] and thin spacer [2].
13
Re-install the bearing [1] and thread the locknut [2] by hand using T-0178 [3] to check for binding in the threads. If the threads on the locknut are damaged during disassembly we recommend replacing it P/N 51-0062.
Important : The chamfered edge is always facing the bearing.
14
Use a torque wrench [1] to torque the locknut [3] to 100 ft-lbs.
Important : The wave springs have been removed as part of a reliability improvement. Motor mount bracket 20-9561 has been updated to 20-9561A to accommodate this change.
Apply grease to the highlighted area then install the worm shaft assembly [1] by threading it into the cluster gear clockwise until it stops.
16
Install the motor bracket [2] using the original hardware [1] and torque the bolts.
Note : Apply grease on the highlighted area and make sure that the o-ring [3] is fully coated.
17
Install the coupler P/N 52-0104  [1] onto the worm shaft [2] making sure that it is shimmed 0.325" from the mating surface [3] then torque the clamping screw to 15 ft-lbs.
Important : Torque the clamping screw to 5 ft-lbs, then 10 ft-lbs, until finally reaching 15 ft-lbs.
18
Re-install the rear cover [2] and torque the rear cover bolts to 25 ft-lbs in a star pattern to ensure even clamping. Ensure that the old gasket is removed and the surface is clean of any lubricants before installing the new gasket.
Important : Make sure that the cover seal [3] does not roll over itself and that the spring inside of it is still in place when installing one the shaft [4].
19
Fill the gearbox with 1 quart of lubricant through the fill plug [1] until it spills out. Refer to Haas Lubrication Table
20
Install the TT-axis motor [2] using hardware [1] and make sure that the key [3] is slid on the motor shaft before tightening the clamping screw on the coupler [4].
21
Reinstall the live tooling alignment dowel blocks [2] and [5].
22
Re-install the torque arm springs [1] along with the snap ring [2] then tap the key [3] back into position. Apply grease on the dowels then proceed by installing a 3/8-16 bolt into the jacking screw hole [5] until the torque arm [4] slides onto the shaft easily. Push the torque arm [4] on the shaft until it is resting onto the snap ring then unbolt the jacking screw and install the clamping bolt [6]. Align the live drive assembly using the  BMT45 Turret - Live Tool Drive - Alignment procedure.
Note : It is recommended to torque the clamping bolt to 45 ft-lb then using a mallet to tap it evenly until it is sitting flush with the snap ring then the clamp bolt gets torqued to 90 ft-lb.
23
Install the LT-axis motor adapter plate [4] then install the LT-axis motor [2]
Remove all tools from the turret.
Change parameter 9.019 to FALSE.
Set parameter 9.078 TT_AXIS TOOL CHANGE OFFSET to 0.
Set parameter 9.140 TT_AXIS GRID OFFSET to 0.
 Press [POSITION]  and make the TT-axis visible by pressing [ALTER] then select the TT-axis and press [ENTER].
[Zero Return] the TT-axis, ignore any alarms. Press [DIAGNOSTICS] to get to the FACTORY parameters tab. Type TT and press [F4] to set the grid offset. [Zero Return] the TT-axis.
In [MDI] command an M43 to unclamp the turret. Handle jog the TT-axis until pocket 1 is in position, visually align the coolant nozzle. Press [ESTOP] to clamp the turret and verify the turret is fully seated.
Press [POSITION] and rotate the TT-axis motor coupler by hand to one end of travel. Record the TT-axis position. Rotate the TT-axis coupler to the other end of travel. Record the TT-axis position. Rotate the TT-axis motor coupler to the middle of the two positions.
Example: (174.780 - 174.610)/2 + 174.610 = 174.695
Press [DIAGNOSTICS] to get back to parameters. Type TT and press [F2] to set the tool change offset.
Change parameter 9.019 to TRUE.
If loads are still high continue with the following steps.
Operate this code in MDI mode:
T1;
T2;
T3;
T4;
T5;
T6;
T7;
T8;
T9;
T10;
T11;
T12;
M99;
 Note: For a 24 station turret command the turret to all 24 tools.
Important: Once clamped at each tool #, verify that the load is always below 5%.
  • Throughout the execution of the program, verify proper clamping / unclamping of the turret, and tool # position as commanded by the program.
  • If it does not operate properly, ensure that the parameters were set correctly per the procedures above.
